Good Afternoon,
I have created a drawing sheet using C# , I also put dimensions in my sheet using the Inventor apis
All the things works perfectly except the arrangement
Below is the attached photo of my drawing sheet and the arrangement of the same which look mess and finding it difficulty to see the view and reading
I want the reading should look like this , separated and clearly visible
I have attached code below in which I have shown my method
Can someone guide me please as I have tried many many ways to do this but failed
Now with lot of hope I am writing this forum
The code snippet shown below uses "Retrieve" method to get all the dimension
DrawingView view1 = drawingDoc.ActiveSheet.DrawingViews[1];
drawingDoc.ActiveSheet.DrawingDimensions.GeneralDimensions.Retrieve(view1);
After getting all the dimensions I have run the another code for deleting similar dimension , and print only the dimensions which comes one time in Drawing sheet
foreach (GeneralDimension dimension in drawingDoc.ActiveSheet.DrawingDimensions.GeneralDimensions)
///MYCODE FOR DELETING THE ANGULAR AND REPETATING DIMENSIONS///
After doing this I have use another code snippet shown below to get arrange the dimension in proper view
but its not arranging properly
ObjectCollection arrange_dimen = inventor_app.TransientObjects.CreateObjectCollection();
foreach (GeneralDimension dimen in drawingDoc.ActiveSheet.DrawingDimensions.GeneralDimensions)
if (dimen.Type == ObjectTypeEnum.kLinearGeneralDimensionObject)
arrange_dimen.Add(dimen);
if (arrange_dimen.Count > 1)
drawingDoc.ActiveSheet.DrawingDimensions.Arrange(arrange_dimen);
Can someone guide me through this , how can I do this
I don't want to do major changes in my code just want to do this changes
Thankyou in Advance
Can you provide a sample drawing and the 'arrange dimensions' function from your code?
Here's an example of what I used, and I got the results that I expected - i.e. the same as if I used the "Arrange Dimensions" feature of the right click context menu.
Sub ArrangeDims()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim Dims As ObjectCollection
Set Dims = ThisApplication.TransientObjects.CreateObjectCollection
Dim oSS As SelectSet
Set oSS = oDoc.SelectSet
Dim oObj As Object
For Each oObj In oSS
If oObj.Type = kLinearGeneralDimensionObject Then
Dims.Add oObj
End If
Next oObj
oDoc.ActiveSheet.DrawingDimensions.Arrange Dims
End Sub
Just double-check that your dimension style is set up correctly. You'll need values for "D" and "E" to be large enough to allow the dimensions to space out correctly.
Personally, I don't like the way 'Arrange Dimensions' works - it would be better if you could create multiple subsets of your dimensions, and use 'Arrange Dimensions' on those, so you still have some control. For each one set, you'll need to manually set a dimension offset so they don't stack on top of one another.
I hope that helps.
This is my arrange dimension code @gerrardhickson
foreach (LinearGeneralDimension dimen in drawingDoc.ActiveSheet.DrawingDimensions.GeneralDimensions) // This code is used to arrange the dimension in the drawing sheet
And for getting the dimension from the sheet I am using retrieve method:
What I am doing @gerrardhickson I am using Retrieve method to get all the dimension , after getting all the dimension I am deleting the repeating dimension and showing the dimension only one time in sheet
and after all the process I am using Arrange dimension process as shown above to arrange the dimension
Is this enough @gerrardhickson or should I do something else
Hoping for best solution
Your code looks OK. Have you checked your drawing styles? Can you provide a sample drawing?
How can I make subsets of dimensions, as I am using Retrieve method and getting all the dimension at once , so how can I make subsets of dimensions.
Can you please guide me through this , as I am not aware about making subsets of dimensions
I have attached the drawing , some parts are not correct but my aim is to just show you the dimensions @gerrardhickson
Ok - as I suspected, your problem is your dimension styles. You need to change your dimension styles for values C, D and E (as per my earlier image) to find values that give you the best result.
HOWEVER.
Because you have horizontal text for all dimensions, this means that your spacing for dimensions on the left and right of the drawing view, need more space than the dimensions on the top and bottom of your view. If you have one drawing style, then you will choose values that make the left and right dimensions look OK, but the top and bottom will be spaced out too far.
To solve this. I created 2 dimension styles - one for left and right dimensions ("Vert Dimensions") and one for the top and bottom dimensions ("Horiz Dimensions") and set different spacing values for these styles so they look neat.
Then, using code, we test for whether the dimension is a vertical or horizontal dimension, assign it to the correct style and arrange it appropriately.
I've attached the file, but here are the dimension styles used for reference:
And here is the code that I used to assign them to styles and arrange:
Sub ArrangeDims()
Dim VertDims As ObjectCollection
Set VertDims = ThisApplication.TransientObjects.CreateObjectCollection
Dim HorizDims As ObjectCollection
Set HorizDims = ThisApplication.TransientObjects.CreateObjectCollection
Dim oObj As Object
Dim oDim As DrawingDimension
Dim dAng As Double
Dim sAng As String
Dim VertDimStyle As DimensionStyle
Dim HorizDimStyle As DimensionStyle
Set VertDimStyle = oDoc.StylesManager.DimensionStyles("Vert Dimensions")
Set HorizDimStyle = oDoc.StylesManager.DimensionStyles("Horiz Dimensions")
Dim DimPos As String
For Each oDim In oDoc.ActiveSheet.DrawingDimensions
' RESET OUR FLAGS
sAng = ""
dAng = 1
' CALCULATE THE ORIENTATION OF THE DIMENSION.
If oDim.IntentOne.PointOnSheet.x = oDim.IntentTwo.PointOnSheet.x Then
sAng = "Vert"
ElseIf oDim.IntentOne.PointOnSheet.y = oDim.IntentTwo.PointOnSheet.y Then
sAng = "Horiz"
Else
dAng = Abs(oDim.IntentOne.PointOnSheet.y - oDim.IntentTwo.PointOnSheet.y) / Abs(oDim.IntentOne.PointOnSheet.x - oDim.IntentTwo.PointOnSheet.x)
End If
' ADD THE DIMENSION TO THE APPROPRIATE OBJECTCOLLECTION
If sAng = "Vert" Or dAng > 1 Then
VertDims.Add oDim
oDim.Style = VertDimStyle
ElseIf sAng = "Horiz" Or dAng < 1 Then
HorizDims.Add oDim
oDim.Style = HorizDimStyle
End If
Next oDim
oDoc.ActiveSheet.DrawingDimensions.Arrange VertDims
oDoc.ActiveSheet.DrawingDimensions.Arrange HorizDims
End Sub
I would also recommend adding some code to help place the dimensions on the appropriate side of the drawing view - some of your dimensions reach almost the full way across the drawing view which is untidy. You can move dimensions by editing the X and Y values of the Dimension.Text.Origin property. Do this before you arrange the dimensions.
Hope that helps.
Good Morning @gerrardhickson
Last doubt , please help me with one thing
I have change your VB code in C# , but getting error as CONTENT ERROR I will show you
The code which I have change is:
if (oDim.IntentOne.PointOnSheet.x == oDim.IntentTwo.PointOnSheet.x)
sAng = "Vert";
else if (oDim.IntentOne.PointOnSheet.y == oDim.IntentTwo.PointOnSheet.y)
sAng = "Horiz";
else
dAng = Math.Abs(oDim.IntentOne.PointOnSheet.y - oDim.IntentTwo.PointOnSheet.y) / Math.Abs(oDim.IntentOne.PointOnSheet.x - oDim.IntentTwo.PointOnSheet.x);
if (sAng == "Vert" || dAng > 1)
VertDim.Add(oDim);
else if (sAng == "Horiz" || dAng < 1)
HoriDim.Add(oDim);
And the error is :
1. Severity Code Description Project File Line Suppression State
Error CS1061 'DrawingDimension' does not contain a definition for 'IntentOne' and no accessible extension method 'IntentOne' accepting a first argument of type 'DrawingDimension' could be found (are you missing a using directive or an assembly reference?)
2. Severity Code Description Project File Line Suppression State
Error CS1061 'DrawingDimension' does not contain a definition for 'IntentTwo' and no accessible extension method 'IntentTwo' accepting a first argument of type 'DrawingDimension' could be found (are you missing a using directive or an assembly reference?)
Can you please guide me such that I can perform my work
Just help me last time and provide me your precious time
Thankyou @gerrardhickson
