AppBrowserCollapseChildrenCmd
dg2405
dg2405
Why does the Command
ThisApplication.CommandManager.ControlDefinitions.Item("AppBrowserCollapseChildrenCmd").Execute
not work? I think it should collapse alle Nodes in the Browser, but nothing happens!
GeorgK
Dim oControlDef As ControlDefinition
Set oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppBrowserCollapseChildrenCmd")
Call oControlDef.Execute
dg2405
Hey george,
thanks for your reply!
Is your code not the same as mine?
When i run your code nothing happens too. Does your code work at your assemblies?
dg2405
I found that the controldefinition is disabled with following code:
Debug.Print oControlDef.Enabled
Trying to enable it with following code not work:
oControlDef.Enabled=True
Any ideas?
GeorgK
Sorry:
Public Sub Test()
Set oDoc = ThisApplication.ActiveEditDocument
Dim oTopNode As BrowserNode
Set oTopNode = oDoc.BrowserPanes.ActivePane.TopNode
Dim oNode As BrowserNode
For Each oNode In oTopNode.BrowserNodes
'If the node is visible and expanded, collapse it
If oNode.Visible = True And oNode.Expanded = True Then
oNode.Expanded = False
Next
End Sub
dg2405
Your code only collapse the nodes under the TopNode, so i have to write a recursive function...
But why is the command "AppBrowserCollapseChildrenCmd" disabled? This command is very fast, a recursive function taks a little time in large assemblies.
dg2405
I found out that the command "AppBrowserCollapseAllCmd" work when i make a rmb on to the browser bevor i start the code. My question is: how can i get rmb menu by api? I tried following code, to simulate a mouse click but the command work almost when i start the macro the 2nd time.
Private Declare PtrSafe Function SetCursorPos Lib "user32" (ByVal x As Long, ByVal Y As Long) As Long
Private Declare PtrSafe Sub mouse_event Lib "user32" (ByVal dwFlags As Long, ByVal dx As Long, ByVal dy As Long, ByVal cButtons As Long, ByVal dwExtraInfo As Long)
Private Const MOUSEEVENTF_RIGHTDOWN As Long = &H8
Private Const MOUSEEVENTF_RIGHTUP As Long = &H10
Sub rmb()
    SetCursorPos 15, 215
    mouse_event MOUSEEVENTF_RIGHTDOWN, 0&, 0&, 0&, 0&
    mouse_event MOUSEEVENTF_RIGHTUP, 0&, 0&, 0&, 0&
End Sub
Any suggestions?
