creating 3d pdf with API and C#.NET
our company has just updated to Inventor 2017 to export some Assembly/Part to 3D PDF.
Now we are now trying to integrate the 3D PDF export in a own developed software with c#.net.
But we have encountered a minor problem and we need support from developpers.
In the help file of the api in Inventor 2017 there is a api sample for “Export to 3D PDF API Sample” in VBA (see below in green)
When trying the same in C#.NET we have the problem that following code will not compile.
The pdfConvertor3d.Publish will not work because of the definition of pdfConvertor3d as object.
What class/interface should we cast TranslatorAddIn.Automation!
Do you have a sample code in C#.NET for the export of 3d pdf like below?
TranslatorAddIn pdf3dAddIn = (TranslatorAddIn)iApp.ApplicationAddIns.ItemById["{3EE52B28-D6E0-4EA4-8AA6-C2A266DEBB88}"];
object pdfConvertor3d = pdf3dAddIn.Automation; //pdf3dAddIn.Automation returns an object or what class should we cast it?
//Publish document
pdfConvertor3d.Publish(idoc, oOptions); //Publish is not valid!
Export to 3D PDF API Sample (VBA) of the API Help
Public Sub PublishTo3DPDF()
    ' Get the 3D PDF Add-In.
    Dim oPDFAddIn As ApplicationAddIn
    Dim oAddin As ApplicationAddIn
    For Each oAddin In ThisApplication.ApplicationAddIns
        If oAddin.ClassIdString = "{3EE52B28-D6E0-4EA4-8AA6-C2A266DEBB88}" Then
            Set oPDFAddIn = oAddin
            Exit For
    Next
    If oPDFAddIn Is Nothing Then
        MsgBox "Inventor 3D PDF Addin not loaded."
        Exit Sub
    Dim oPDFConvertor3D
    Set oPDFConvertor3D = oPDFAddIn.Automation
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    ' Create a NameValueMap object as Options
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Options
    oOptions.Value("FileOutputLocation") = "c:\temp\test.pdf"
    oOptions.Value("ExportAnnotations") = 1
    oOptions.Value("ExportWokFeatures") = 1
    oOptions.Value("GenerateAndAttachSTEPFile") = True
    oOptions.Value("VisualizationQuality") = kHigh
    ' Set the properties to export
    Dim sProps(0) As String
    sProps(0) = "{F29F85E0-4FF9-1068-AB91-08002B27B3D9}:Title"  ' Title
    oOptions.Value("ExportAllProperties") = False
    oOptions.Value("ExportProperties") = sProps
    ' Set the design views to export
    Dim sDesignViews(1) As String
    sDesignViews(0) = "Master"
    sDesignViews(1) = "View1"
    oOptions.Value("ExportDesignViewRepresentations") = sDesignViews
    'Publish document.
    Call oPDFConvertor3D.Publish(oDocument, oOptions)
End Sub
Regards
Enzo Naso
c_hoppen
Is there no solution? I also need to export 3d pdf using c# .net.
adam.nagy
Autodesk Support
Autodesk Support
Just use dynamic:
dynamic pdfConvertor3d = pdf3dAddIn.Automation;
Cheers,
Adam Nagy
Autodesk Platform Services
c_hoppen
No No No thats too easy! Impossible! 😉
Christoph
YuhanZhang
Declare the variable using 'dynamic' does work. Attached a sample C# project for this, you can open a part/assembly and run the code to check the result. You may need to modify the sDesignViews array to specify proper values for it before running it.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
jmacapagal2CD9H
Hello, just came here to ask about the same problem but I am using the same code from a custom Addin that I created. I got this error when publishing. It is working If I use it on a external application.
