Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Always Publish DWF in Express Mode
2 REPLIES 2
jmockEAFCX
257 Views, 2 Replies
I am adding the code to publish DWF files for assemblies (https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-5E8D441D-0F9E-4E54-8E49-3EEA8FEE8FCE) into a macro but I want to make sure it publishes using the "Express" mode every time. Right now it generates the file based on whichever mode I used last. Anyone know if that's possible?
Labels (3)
2 REPLIES 2
Michael.Navara
in reply to: jmockEAFCX
You need to set appropriate options for translator. Not tested, but I expect this option is in
oOptions.Value("Publish_Mode") = kCustomDWFPublish
Where value is one of DWFPublishModeEnum Enumerator
Complete set of options are described in API help. Here is a list without description
Translator: DWFx
kAssemblyDocumentObject
-- SaveCopyAsOptions --
Publish_All_Sheets           0
Publish_3D_Models            0
Launch_Viewer  1
Password
Publish_Mode   62721
Enable_Large_Assembly_Mode   0
Enable_Measure               1
Enable_Printing              1
Enable_Markups               1
Enable_Markup_Edits          1
Output_Path
Include_Sheet_Tables         1
Sheet_Metal_Flat_Pattern     0
Sheet_Metal_Style_Information              0
Sheet_Metal_Part             1
Weldment_Preparation         0
Weldment_Symbol              0
BOM_Structured               1
BOM_Parts_Only               1
Animations     0
Instructions   0
iAssembly_All_Members        0
iAssembly_3D_Models          0
iPart_All_Members            0
iPart_3D_Models              0
Publish_Component_Props      1
Publish_Mass_Props           1
Include_Empty_Properties     0
Publish_Screenshot           0
Screenshot_DPI               96
Facet_Quality  69379
Force_Facet_Recompute        0
Facet_Recompute_Tolerance    0,001
Override_Sheet_Color         0
Sheet_Color    0
Sheet_Range    14081
Custom_Begin_Sheet           1
Custom_End_Sheet             1
All_Color_AS_Black           0
Remove_Line_Weights          0
Vector_Resolution            400
TranscriptAPICall            0
-- OpenOptions --
-- NO OpenOptions --
jmockEAFCX
I had to use the 62721 value from the link you posted rather than the name but that enumerator is what I needed, thanks!
