Adding Surface Texture to FlatPattern View
miha_bokan
miha_bokan
I am trying to enrich my "auto-weldment-drawing", which automatically adds all necessary views and also raw parts that need to be cut, bend, before welding.
My program works actually pretty good, but I want to add surface texture symbol to sheet metal flat pattern views. There isn't much resources about ilogc-surface, so I am kind of stuck... 😕
Anyone up to the challenge?
marcin_otręba
hi,
you can start from this:
Dim drw As DrawingDocument = ThisDoc.Document
Dim osheet As Sheet = drw.ActiveSheet
For Each oDv As DrawingView In osheet.DrawingViews
	If oDv.IsFlatPatternView Then
		drw.SelectSet.Clear
		drw.SelectSet.Select(oDv)
		If oDv.Camera.Eye.X > oDv.Camera.Eye.Z Or oDv.Camera.Eye.Y > oDv.Camera.Eye.Z Then ' if flat pattern view is side view
			Dim oiptdoc As PartDocument = oDv.ReferencedDocumentDescriptor.ReferencedDocument
			Dim ft As FlatPattern = oiptdoc.ComponentDefinition.flatpattern
			Dim oFT As Object = ft.TopFace
			Dim oFB As Object = ft.BottomFace
			Dim oDvCT As DrawingCurve = oDv.DrawingCurves(oFT)(1) ' get first drawing view curve from top flatpattern face
	 		Dim oMidPointT As Point2d = oDvCT.MidPoint
			Dim oDvCB As DrawingCurve = oDv.DrawingCurves(oFB)(1) ' get first drawing view curve from bottomflatpattern face
	 		Dim oMidPointB As Point2d = oDvCB.MidPoint
	    	' Set a reference to the TransientGeometry object.
	    	Dim oTG As TransientGeometry= ThisApplication.TransientGeometry
	    	Dim oLeaderPointsT As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	    	' Create a few leader points.
	    	Call oLeaderPointsT.Add(oTG.CreatePoint2d(oMidPointT.X, oMidPointT.Y))
	     	' Create an intent and add to the leader points collection.
		    ' This is the geometry that the leader text will attach to.
		    Dim oGeometryIntentT As GeometryIntent = osheet.CreateGeometryIntent(oDvCT,oMidPointT)
		    Call oLeaderPointsT.Add(oGeometryIntentT)
		  	Dim oLeaderPointsB As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
		    Call oLeaderPointsB.Add(oTG.CreatePoint2d(oMidPointB.X, oMidPointB.Y))
		    Dim oGeometryIntentB As GeometryIntent = osheet.CreateGeometryIntent(oDvCB,oMidPointB)
		    Call oLeaderPointsB.Add(oGeometryIntentB)
		 	Dim oSymbolT As SurfaceTextureSymbol
		 	oSymbolT = osheet.SurfaceTextureSymbols.Add(oLeaderPointsT,kMaterialRemovalProhibitedSurfaceType)
			Dim oSymbolB As SurfaceTextureSymbol
		    oSymbolB = osheet.SurfaceTextureSymbols.Add(oLeaderPointsB,kMaterialRemovalProhibitedSurfaceType)
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
miha_bokan
The orientation of symbol is sometimes not right, but still good enough for me and use.
Tnx a ton !
Stephane_Hemberger
Hello everyone,
Thanks a lot for the detailed explanation and clear solution.
Has anyone found a way to define the orientation or the side of the line on which the surface texture symbol should be drawn?
I'm currently facing the issue that I don't know how to set this, and the symbol always appears on the side that is facing downward - regardless of whether it's the "material" side or the "air" side of the line.
Thanks in advance for any replies!
Best regards,
Stéphane Hemberger
marcin_otręba
ou can play with leaderpoints:
		drw.SelectSet.Clear
			If Abs(oMidPointT.X - oDv.Left) >= oDv.Width Then
				Call oLeaderPointsT.Add(oTG.CreatePoint2d(oDv.Left+ oDv.Width, oMidPointT.Y))
				Else
					Call oLeaderPointsT.Add(oTG.CreatePoint2d(oDv.Left , oMidPointT.Y))
		'Call oLeaderPointsT.Add(oTG.CreatePoint2d(oMidPointT.X,oDv.Left))
		  If Abs(oMidPointB.X - oDv.Left) >= oDv.Width Then
				Call oLeaderPointsB.Add(oTG.CreatePoint2d(oDv.Left, oMidPointB.Y))
				Else
					Call oLeaderPointsB.Add(oTG.CreatePoint2d(oDv.Left + oDv.Width, oMidPointB.Y))
Next
