ou can play with leaderpoints:
Dim drw As DrawingDocument = ThisDoc.Document
Dim osheet As Sheet = drw.ActiveSheet
For Each oDv As DrawingView In osheet.DrawingViews
If oDv.IsFlatPatternView Then
drw.SelectSet.Clear
drw.SelectSet.Select(oDv)
If oDv.Camera.Eye.X > oDv.Camera.Eye.Z Or oDv.Camera.Eye.Y > oDv.Camera.Eye.Z Then ' if flat pattern view is side view
Dim oiptdoc As PartDocument = oDv.ReferencedDocumentDescriptor.ReferencedDocument
Dim ft As FlatPattern = oiptdoc.ComponentDefinition.flatpattern
Dim oFT As Object = ft.TopFace
Dim oFB As Object = ft.BottomFace
Dim oDvCT As DrawingCurve = oDv.DrawingCurves(oFT)(1) ' get first drawing view curve from top flatpattern face
Dim oMidPointT As Point2d = oDvCT.MidPoint
Dim oDvCB As DrawingCurve = oDv.DrawingCurves(oFB)(1) ' get first drawing view curve from bottomflatpattern face
Dim oMidPointB As Point2d = oDvCB.MidPoint
' Set a reference to the TransientGeometry object.
Dim oTG As TransientGeometry= ThisApplication.TransientGeometry
Dim oLeaderPointsT As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
' Create a few leader points.
If Abs(oMidPointT.X - oDv.Left) >= oDv.Width Then
Call oLeaderPointsT.Add(oTG.CreatePoint2d(oDv.Left+ oDv.Width, oMidPointT.Y))
Else
Call oLeaderPointsT.Add(oTG.CreatePoint2d(oDv.Left , oMidPointT.Y))
End If
' Create an intent and add to the leader points collection.
' This is the geometry that the leader text will attach to.
Dim oGeometryIntentT As GeometryIntent = osheet.CreateGeometryIntent(oDvCT,oMidPointT)
'Call oLeaderPointsT.Add(oTG.CreatePoint2d(oMidPointT.X,oDv.Left))
Call oLeaderPointsT.Add(oGeometryIntentT)
Dim oLeaderPointsB As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
If Abs(oMidPointB.X - oDv.Left) >= oDv.Width Then
Call oLeaderPointsB.Add(oTG.CreatePoint2d(oDv.Left, oMidPointB.Y))
Else
Call oLeaderPointsB.Add(oTG.CreatePoint2d(oDv.Left + oDv.Width, oMidPointB.Y))
End If
Dim oGeometryIntentB As GeometryIntent = osheet.CreateGeometryIntent(oDvCB,oMidPointB)
Call oLeaderPointsB.Add(oGeometryIntentB)
Dim oSymbolT As SurfaceTextureSymbol
oSymbolT = osheet.SurfaceTextureSymbols.Add(oLeaderPointsT,kMaterialRemovalProhibitedSurfaceType)
Dim oSymbolB As SurfaceTextureSymbol
oSymbolB = osheet.SurfaceTextureSymbols.Add(oLeaderPointsB,kMaterialRemovalProhibitedSurfaceType)
End If
End If
Next
