Adding Filter Settings to Parts List in iLogic
przemyslaw_sokolowski
Autodesk Autodesk
Message 1 of 9
I am trying to apply "Test" View Representation Filter Settings to Parts List. When I run my code in VBA the "Primary" View is applied. When I am trying to run it in iLogic Inventor crashes. Could you give me a hint what is wrong in my code?
Sub main
	Dim oDrawing As Inventor.DrawingDocument
	oDrawing = ThisApplication.ActiveDocument
	Dim oView As DrawingView
	oView = oDrawing.ActiveSheet.DrawingViews.Item(1)
	Dim oPartsList As PartsList
	oPartsList = oDrawing.ActiveSheet.PartsLists.Item(1)
	Dim oAssyComp As AssemblyComponentDefinition
	oAssyComp = oPartsList.ReferencedFile.DocumentDescriptor.ReferencedDocument.ComponentDefinition
	Dim oViewRep As DesignViewRepresentation
	oViewRep = oAssyComp.RepresentationsManager.DesignViewRepresentations.Item("Test")
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oOptions.Add(“AssemblyViewRepresentation”, oViewRep)
	oPartsList.FilterSettings.Enabled = True
    Dim oPartsListFItem As PartsListFilterItem
	oPartsListFItem=oPartsList.FilterSettings.Add(kAssemblyViewRepresentationFilterItem,oOptions)
End Sub
Przemek
Przemyslaw Sokolowski
Technical Sales Specialist
Replies (8)
Message 2 of 9
Andrii_Humeniuk
Hi @przemyslaw_sokolowski . It looks like you are trying to add a filter of the View Representation category, while it is already present in the filter list. You need to clear the existing filters and add a new one.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 9
WCrihfield
Hi @przemyslaw_sokolowski.  These are just educated guesses at this point, because I haven't been updated to the 2024.1 version yet, but I would suggest looking into the following changes:
Dim oAssyDoc As AssemblyDocument = oPartsList.ReferencedDocumentDescriptor.ReferencedDocument
oAssyComp = oAssyDoc.ComponentDefinition
...instead of:
And, including the Enum name before the Enum variation's name, like this:
oPartsListFItem = oPartsList.FilterSettings.Add(PartsListFilterItemTypeEnum.kAssemblyViewRepresentationFilterItem, oOptions)
VBA encourages us to not include it, but it is always very much recommended in iLogic rules, unless you prefer the numerical variation value instead, which can be harder to read later.
Then, after you have that newly added PartsListFilterItem to that oPartsListFItem variable, you may want to take the extra step of Enabling that item.
oPartsListFItem.Enabled = True
The main other things are simply making sure there is a DrawingView, and PartsList on the 'active' sheet, and that there is actually a DVR (DesignViewRepresentation) object in that assembly named "Test".
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 9
Thanks for the tips, unfortunately they did not help. What I noticed is that if I remove oOptions (which is optional) from the line:
oPartsListFItem=oPartsList.FilterSettings.Add(PartsListFilterItemTypeEnum.kAssemblyViewRepresentationFilterItem)
The code did not crash Inventor but creates filter for "Primary" Design View Representation. So it looks like something is wrong with the definition of NameValueMap.
Message 5 of 9
Thanks for pointing that out. I created the screenshot to prove that there is "Test" Design View Representation defined in assembly.  If the filter is applied the code fails to create a new one.
Message 6 of 9
WCrihfield
Hi @przemyslaw_sokolowski.  This may sound overly simple, and a stretch, but have you tried 'declaring' the oOptions variable as a NameValueMap before setting its value.  This is rarely an issue, but I have seen similar situations stump up iLogic rules before, so I just thought it was worth mentioning.
Wesley Crihfield
Message 7 of 9
That was it. Thank you very much  🙂
Message 8 of 9
Luis_Pacheco_3D
From which inventor version does this code work?
Message 9 of 9
WCrihfield
Hi @Luis_Pacheco_3D.  The online documentation for the PartsList.FilterSettings property indicates that it was added in 2024.1 version.
Edit:  Here are two more related links:
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-A0B07812-EB30-4898-B53E-1112CF02DB2C
https://forums.autodesk.com/t5/inventor-ideas/parts-list-filter-settings/idi-p/6238772
Wesley Crihfield
