Hi there,
I am trying to add / edit welding symbols on a drawing with iLogic. I can't seem to find any information on how to do this.
I have managed to add / edit dimensions and feature control frames but cannot fine the object for welds.
Any help would be greatly appreciated.
thanks,
John
Hi johnster100,
Last time I looked into this issue it seemed there was no way to access the weld symbols via the API.
You can try creating your own sketched symbols. This may be a way for you. You can find some reference about working with the object SketchedSymbol here:
http://adndevblog.typepad.com/manufacturing/2012/08/creating-sketched-symbols.html
I hope it helps. Good luck!
thanks for the reply.
it seems strange that there is not really a way to automate a drawing which requires welding symbols. Could anyone at Autodesk advise if this functionality will be coming anytime soon?
It's a pretty major requirement for any fabrication drawing.
thanks,
John
You may want to support this idea:
Best regards.
When it's 2040, let me know, maybe I'll still be alive, and maybe the api will be done. 🙂
Add Surface Texture Symbol = It would be a great benefit to use this functionality via iLogic as well
