Add planes and have formula (with parameters) in Equation of Plane.
J.VandeMerckt
J.VandeMerckt
Hi Forum
I'm trying to add a plane to my model using Ilogic.
I want to offset the plane using the "pLength" parameter.
This formula should also stay in the parameter equation of the plane.
The Code i'm trying looks like this;
oDef = ThisDoc.Document.ComponentDefinition
Dim oWPlane As WorkPlane
oWPlane = oDef.WorkPlanes.AddByPlaneAndOffset(oDef.WorkPlanes("YZ Plane (Front)"), Parameter("-pLength")/2)
oWPlane.Name = "YZ Plane (Mid)"
oWPlane = oDef.WorkPlanes.AddByPlaneAndOffset(oDef.WorkPlanes("YZ Plane (Front)"), Parameter("-pLength"))
oWPlane.Name = "YZ Plane (Back)"
So Right now the formula pLength gets the wrong result.
But even if it was the correct result the equation just shows the result and not the formula.
Parameter in the end should look like this:
Let me know if i wasn't clear.
Best regards
Justin
Stakin
oWPlane = oDef.WorkPlanes.AddByPlaneAndOffset(oDef.WorkPlanes("YZ Plane (Front)"), (-1)*Parameter("pLength")/2)
oWPlane = oDef.WorkPlanes.AddByPlaneAndOffset(oDef.WorkPlanes("YZ Plane (Front)"), (-1)*Parameter("pLength"))
Try this
J.VandeMerckt
Chat gpt helped me already.
Dim pOffsetMidplane As String = "-pLength / 2"
Dim pOffsetBackplane As String = "-pLength"
oWPlane = oDef.WorkPlanes.AddByPlaneAndOffset(oDef.WorkPlanes("YZ Plane (Front)"), pOffsetMidplane)
oWPlane = oDef.WorkPlanes.AddByPlaneAndOffset(oDef.WorkPlanes("YZ Plane (Front)"), pOffsetBackplane)
 Didn't know you declare a formula as a string.
Ty for helping either way.
