Add Handler on Command Check Out
davdelomb
davdelomb
I've wrote some code that checks my "description"  and "subject" property value.
For now the code is activated when the drawing is activated, but I want to add a handler on the command Check Out..
But I can't seem to figure it out to check if the command is activated?
davdelomb
Already Solved !
  AddHandler VaultCheckOut.OnTerminateCommand, AddressOf VaultCheckOut_OnActivateCommand
  AddHandler VaultCheckIn.OnActivateCommand, AddressOf VaultCheckIn_OnActivateCommand
    Private Sub VaultCheckOut_OnActivateCommand(ByVal CommandName As String, ByVal context As NameValueMap)
        If CommandName = "VaultCheckout" Or CommandName = "VaultCheckoutTop" Then
            DataOphalenIPT()
    End Sub
Private Sub VaultCheckIn_OnActivateCommand(ByVal CommandName As String, ByVal context As NameValueMap) If CommandName = "VaultCheckin" Or CommandName = "VaultCheckinTop" Then DataOphalenIPT() End If End Sub
