Ilogic read excel cell with format
is it possible to read excel cells with the format (different fontsizes, underlined words,...)
At the moment i am using this code:
SyntaxEditor Code Snippet
GoExcel.FindRow("\\SV-VAULT2\VaultDaten\Vorlagen allgemein\Beschriftung Zeichnungskopf.xlsx", "Tabelle1", "Parameter", "=", "SYMBOLTEXT1")
iProperties.Value("Custom", "SYMBOLTEXT1") = GoExcel.CurrentRowValue(Sprache)
But i can read the information only and not the excel format.
Thanks in advance!
André
jurgen.galba
- Aut viam inveniam aut faciam -
(I shall either find a way or make one.)
frederic.vandenplas
Sorry, i've posted under my collegue his account
This sample checks if the first cell is bold or not, you can modify change it according to your needs
This is done using COM, so you may check for errors, other open documents and so one before proceeding
ExcelApp = GetObject(,"Excel.Application")
'MsgBox(ExcelApp.activeworkbook.ActiveSheet.cells(1,1).Value)
If ExcelApp.activeworkbook.ActiveSheet.cells(1,1).Font.Bold = True Then
MsgBox("Cell 1,1 is Bold")
Else
MsgBox("Cell 1,1 is not Bold")
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
RoyWickrama_RWEI
Currently I am doing a lot with reading from and writing to type of coding to support huge assemblies.
The code is giving me some idea: will explore over the weekend.
