Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Add All family with the same Standard Organizstion from content center to an listbox in VBA Userform
1 REPLY 1
Darkforce_the_ilogic_guy
419 Views, 1 Reply
I want to userform to Place componemt form Content Center.   but Only all for the Standard Organizstion = "Kalle"
for doing this I need to read all the right information into an listbox in VBA.
I am not sure what to change in the code below
Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Fasteners").ChildNodes.Item("Bolts").ChildNodes.Item("Hex Head")
' Find a specific family. In this case it's using the display name, but any family
' characteristic could be searched for.
Dim family As ContentFamily
Dim checkFamily As ContentFamily
For Each checkFamily In hexHeadNode.Families
MsgBox (checkFamily.DisplayName)
If checkFamily.DisplayName = "DIN EN 24016" Then
Set family = checkFamily
Exit For
End If
Next
1 REPLY 1
Not that bedst code But it works so far
Private Sub UserForm_Activate()
Dim familyName(24, 1)
Dim number As Integer
number = 0
'Set list = New ArrayList
 Dim hexHeadNode As ContentTreeViewNode
    Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("Angles")
    If checkFamily.StandardOrganization = "Kallesoe" Then
    familyName(number, 0) = checkFamily.DisplayName
    number = number + 1
        'If checkFamily.DisplayName = "Threaded Rod" Then
          ' MsgBox (checkFamily.DisplayName)
           ' Exit For
       ' End If
       End If
    Next
    'New profil Type
    Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("Channels")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
    Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("I-Beams")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
    Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("Other")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
    Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("Round Bars")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
    Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("Round Tubes")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
    Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("Square/Rectangular Tubes")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
    Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("Square/Rectangular/Hex Bars")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
      Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Structural Shapes").ChildNodes.Item("Tees")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
       Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Other Parts")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
        Set hexHeadNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Other Parts").ChildNodes.Item("Cable Chains")
    number = number + 1
           ' Exit For
       ' End If
       End If
    Next
    UserForm2.ListBox1.List = familyName
End Sub
End Sub
Tags (1)
Technology Administrators
