Add a view representation
4 REPLIES 4
Cosmin_V
434 Views, 4 Replies
Cosmin_V
Hi everbody,
I put together lines of code from the forum, but something doesn't work right.
I want to make an external rule that will make invisible all the parts in all the subassemblies, except for those in "Reference".
So I can see only the parts in "Reference" in the entire structure of the assembly.
And add this to a new view representation
In my code this happens, but only to the parts that are in the top assembly. All the rest that are in other assemblies and subassemblies become invisible.
'define current document
Dim openDoc As Document
openDoc = ThisDoc.Document
'this assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'look at all of the components in the assembly
Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition
'define view rep
Dim oViewRep As DesignViewRepresentation
'define an arraylist to hold the list of  view rep names
 Dim NameList As New ArrayList()
'check to see if the arraylist contains the desired view rep
Try
	oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Reference parts")
	Catch
		NameList.Contains("Reference parts")
				If Not NameList.Contains("Reference parts")  Then
					oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Reference parts")
					oViewRep.Activate
				Else If NameList.Contains("Reference parts") Then
					oViewRep.Activate
				End If
			End Try
'zoom all
ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
'Turn visibility of if....
For Each oOcc As ComponentOccurrence In oCompDef.Occurrences
	If oOcc.BOMStructure = BOMStructureEnum.kNormalBOMStructure Or oOcc.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure Or
		oOcc.BOMStructure = BOMStructureEnum.kInseparableBOMStructure Or oOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Then
		oOcc.Visible = False
	End If
	If oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
		oOcc.Visible = True
	End If
Next
ThisApplication.ActiveView.Update()
oViewRep.Locked = True
Can somebody help me to finish this?
Hi everbody,
'define view rep
Try
	Catch
					oViewRep.Activate
					oViewRep.Activate
				End If
			End Try
'zoom all
	End If
		oOcc.Visible = True
	End If
Next
4 REPLIES 4
FINET_Laurent
in reply to: Cosmin_V
FINET_Laurent
Hi @Cosmin_V,
From a quick look I can see that when checking for the reference property, your are going trought the Occurrence collection. This collection represents - only - the top assemblies / parts in the browser. If you want to go deeper in the tree, going trough the part of a sub assembly for instance, you could instead use the Occurences.AllLeafOccurences collection instead. This would instead go trough each individual part of the assembly, regardless of  the type (top / sub assembly / sub part / ...). I did the fix on line 36:
'define view rep
Try
	Catch
					oViewRep.Activate
					oViewRep.Activate
				End If
			End Try
'zoom all
For Each oOcc As ComponentOccurrence In oCompDef.Occurrences.AllLeafOccurrences
	End If
		oOcc.Visible = True
	End If
Next
 Can you give it a try ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Hi @Cosmin_V,
'define view rep
Try
	Catch
					oViewRep.Activate
					oViewRep.Activate
				End If
			End Try
'zoom all
	End If
		oOcc.Visible = True
	End If
Next
Kind regards,
FINET L.
Cosmin_V
in reply to: FINET_Laurent
Cosmin_V
Tanks @FINET_Laurent
It works for some parts in the first assembly, but after that an error occurs on line 39
FINET_Laurent
FINET_Laurent
@Cosmin_V ,
I can't debug the code for you. For this I would need all the assembly and the parts to test. Can you provide us with the files so we can test out ? A dirty fix would be to put the command in a try /catch and skip a beat if it fails :
Try
Catch
	Continue For
End Try
Kind regards,
FINET L.
@Cosmin_V ,
Try
Catch
	Continue For
End Try
Kind regards,
FINET L.
Cosmin_V
Cosmin_V
@FINET_Laurent
There it will be something else...😁
Can somehow to turn back the visibility on the parts which are place in the "Reference" assemblies?
Because some of the subassemblies are in "reference" but has parts "Normal" and I want to see all pars in to this "reference" subassemblies.
@FINET_Laurent
