(I'm a newbie with VBA Inventor.)
I'd like to write a private sub in a module that would be called from the main Sub.
I'd like to have the active document as a parameter for this private sub but I can't find the solution to make it works.
Thanks for any help
Dim oInvDoc As Document
Set oInvDoc = ThisApplication.ActiveDocument
If oInvDoc.DocumentType = kAssemblyDocumentObject Then
updateTag(oInvDoc)
endif
Private Sub updateTag(oDoc As Document)
Dim oDocu As Document
Set oDocu = oDoc
End Sub
