Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Accessing Preparation Items in Drawing View - Model State, iLogic code (API)
5 REPLIES 5
ReneRepina
1250 Views, 5 Replies
is there any possibility to access Preparation Items inside Drawing View - Model State dialog with iLogic code (API)?
I also saw few thread regarding accessing the "Model State" inside "Drawing View" is not possible. Is there any new news (or implementation) on that?
Best regards,
Rene Repina
Labels (7)
5 REPLIES 5
YuhanZhang
in reply to: ReneRepina
The DrawingView.SetWeldmentState allows you to set the weldment state circled in the picture. Please refer to the documentation for more details:
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-EEF8071C-6ABA-42E1-A7D1-72B18B0D8756
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
ReneRepina
in reply to: YuhanZhang
@YuhanZhang Thank you for your help! This is what I needed.
freesbee
Dear Rocky @YuhanZhang ,
doing some additional research on this topic I have landed at this video from @Anonymous.sekar.g which makes me think that the following code:
Sub TEST()
Dim oDrawDoc as DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet as Sheet
Dim oWeldState As WeldmentStateEnum
Dim oWeldObject As Object
Dim oDrawView As DrawingView
For Each oSheet In oDrawDoc.Sheets
  For Each oDrawView In oSheet.DrawingViews
    If oDrawView.ViewType = kStandardDrawingViewType Then
      Call oDrawView.GetWeldmentState(oWeldState, oWeldObject)
  Next
Next
end sub
fails on the method GetWeldmentState (as it is in happening in my specific case as well).
So I imagine that sometimes in the past you have addressed the INVGEN-17324 issue.
Would you be so kind to share on which release/update this issue has been addressed, or eventually share the right syntax to use this method?
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
freesbee
in reply to: freesbee
...oh... I just discovered that INVGEN-17324 has been fixed on 2020  😓
Massimo Frison
YuhanZhang
You're right, it was fixed for Inventor 2020.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
