Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Access iProperties of apart in an Assembly from a Drawing
5 REPLIES 5
fsdolphin
393 Views, 5 Replies
I have a drawing with an assembly in it and I would like to be able to access the iProperties of the parts used in the assembly to do some comparison.
With the following code, I'm able to iterate through all of the parts and get their names, but the one thing I haven't been able to figure out is how to get their description from their iProperties.
Sub Main()
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oActiveSheet As Sheet
    oActiveSheet = oDoc.ActiveSheet
    Dim oDrawingView As DrawingView
    oDrawingView = oActiveSheet.DrawingViews(1)
    Dim oRefDoc As AssemblyDocument
    oRefDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim oAssDef As AssemblyComponentDefinition
    oAssDef = oRefDoc.ComponentDefinition
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oAssDef.Occurrences
	         ' Here I can get the name and do some comparison.
		 If oOcc.Name.Contains("BRKT") Then
		 	Call oDrawingView.SetVisibility(oOcc, True)
		 Else
		 	Call oDrawingView.SetVisibility(oOcc, False)
		' ISSUE: Here is where I'm having issues getting their description.
		If oOcc.iProperties.Value("Project", "Description").Contains("BRKT") Then
                  MessageBox.Show("Part contains BRKT...")
    Next
End Sub
I'm getting error:
Public member 'iProperties' on type 'ComponentOccurrence' not found.
What am I missing?
5 REPLIES 5
JamieVJohnson2
in reply to: fsdolphin
iProperties belong to Component Definition of the Document that the Component Occurrence is referencing.
jvj
fsdolphin
in reply to: JamieVJohnson2
Ok, but how do I reference them? Thanks.
JamieVJohnson2
iLogic has a series of shortcuts in the system called ThisRule that is always active...  so when you type in iProperties.Value() you get 2 options from the ThisRule namespace.  the second option allows you to enter a component or document name, and it does all the background work for you.  So try this:
iProperties.Value(compOcc.Name, "DesignTrackingProperties", "Description")
or the full long vb.net method:
desc = GetDescription(occ.document).value
Public Property DesignTrackingPropertySetID As String = "{32853F0F-3444-11D1-9E93-0060B03C1CA6}"
    Public Function GetDescription(ByRef invDoc As Inventor.Document) As Inventor.Property
        Dim props As Inventor.PropertySet = invDoc.PropertySets.Item(Tools.DesignTrackingPropertySetID)
        Dim desc As Inventor.Property = props.Item("Description")
        Return desc
    End Function
jvj
fsdolphin
@JamieVJohnson2   I keep getting an error when I try...
iProperties.Value(oOcc.Name, "Project", "Description")
or
iProperties.Value(oOcc.Name, "DesignTrackingProperties", "Description")
Error:
Object reference not set to an instance of an object.
JamieVJohnson2
Object reference not set to an instance of an object...
The Object 'oOcc' (you component occurrence I presume) is currently 'nothing'.  Did you every anywhere say oOcc = something?  This is most likely happening at the point where you are attempting to get oOcc.Name.  The name of nothing is... what I can't get the name of a nothing???
Otherwise Inventor would error out with 'Parameter is Incorrect" if the .Value command didn't like the imput.
jvj
Technology Administrators
