Access and change inventor parameters using vb.net
I am using vb.net code in visual studio to use a custom form to update the inventor model. I found code on the "mod the machine" site but it is not working for me. Here is what I have:
Dim _invApp As Inventor.Application
Dim oParameter As Inventor.Parameters = _invApp.ActiveDocument.ComponentDefinition.Parameters
Private Sub WheelSize_Leave(sender As Object, e As EventArgs) Handles WheelSize.Leave
Dim oWheelSize As Inventor.Parameter = oParameter.Item("Wheel_Size1")
oWheelSize.Expression = WheelSize.Text
I get the issues with the ComponentDefinition.Parameters as it is not recognizing that as anything meaningful. Does anyone know what the issue is?
rjay75
Without seeing more of the code I'd say it's that you don't have a reference to the currently running Inventor Application. Do you ever set the variable _invApp anywhere. This needs to be set to the running Inventor Application first.
How are you running your code? What method are you using to start it?
Here is the code that starts inventor:
Dim _started As Boolean = False
Public Sub InvOpen()
Try
_invApp = GetObject(, "Inventor.Application")
_invApp.Quit()
Dim invAppType As Type = _
GetTypeFromProgID("Inventor.Application")
_invApp = CreateObject("Inventor.Application")
_invApp.Visible = True
_started = True
Catch ex As Exception
Try
_started = True
Catch ex2 As Exception
MsgBox(ex2.ToString())
MsgBox("Unable to get or start Inventor")
End Try
End Try
End Sub
rjay75
The _invApp is not set yet at this point:
The variable _invApp is not set until the Sub InvOpen() is run. In your code you're closing and starting a new instance of Inventor. At that point there's no document open. You can't access the ActiveDocument or anything else til a document is open.
Just declare oParameter like you did _invApp at that point.
After Inventor is opened and a document is opened you can set oParameter.
Okay, I think I understand what you are saying. I do have code that sets a project and opens a file. At this point i should be able to set oParameters. I will give it a try again but I think I tried it that way before. The interesting thing is the intellisense doesnt give give me componentdefinition as an option......
I will let you know how it goes when I get a chance.
Sorry I didn't get back with you.... I did get it to work. I forget exactly what the key was but all this was very helpful. Thanks!
