Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
64 bit VBA
5 REPLIES 5
381 Views, 5 Replies
64 bit VBA
I have a macro that worked great in IV 2008 and prior. IV 2009 64 bit is a problem. Most things work but I am having crash problems with accessing Units of measure and Sheet metal syle material name. It will work for the first part but as it brings up the second it freezes and then crashes hard.
I use the following to get to the material name:
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Set oModel = ThisApplication.Documents.Open(ItemFilePath, False)
Set oSheetMetalCompDef = oModel.ComponentDefinition
TextBox5.Value = CStr(oSheetMetalCompDef.ActiveSheetMetalStyle.Material.Name)
The following fo Units of measure:
Dim oUOM As UnitsOfMeasure
Set oUOM = DocM.UnitsOfMeasure
' Obtain the Parameters collection
Dim oParamsU As Parameters
Set oParamsU = DocM.ComponentDefinition.Parameters
' Obtain the Model Parameters collection
Dim oModelParamU As ModelParameters
Set oModelParamU = oParamsU.ModelParameters
' Get document units
ModelUnit = oUOM.GetStringFromType(kDefaultDisplayLengthUnits)
5 REPLIES 5
Can you provide a full sample that demonstrates your problem? I tested the
code from your post but it works fine for me.
Brian Ekins
Autodesk Inventor API
I know I am a bit of a newbe but here it is. The purpose is to get reference numbers for sheet metal parts and show the thickness and material, qty and so on. The code works fine in 32 bit. In 64 bit it will bring up the first sheet metal part in the parts list ok and then on next it shows the second one and freezes and then crashes IV09. I have a column in the parts list for the file path. If this is still not enough please give me an email so I can send files for full functionality.
Private Sub GetSheetMetal()
Dim oDocNum, ProjNum, ItemNum, ItemFilePath As String
If a <> 0 And b <> 0 And c <> 0 Then
' Iterate through the contents of the parts list.
NextRow:
' Get the current row.
ItemFilePath = ""
Set oRow = oPartList.PartsListRows.Item(f)
oRowVis = oRow.Visible
If oRowVis Then
' If row is visible and is sheet metal then get file path
If oRow.Item(c).Value = "Sheet Metal" Then
ItemFilePath = CStr(oRow.Item(b).Value)
If ItemFilePath <> "" Then
' Get the sheet metal component definition. Because this is a part document whose
' sub type is sheet metal, the document will return a SheetMetalComponentDefinition
' instead of a PartComponentDefinition.
ProjNum = oDrawDoc.PropertySets.Item("Design Tracking Properties").Item("PROJECT").Value
ItemNum = CStr(oRow.Item(a).Value)
oDocNum = oDrawDoc.PropertySets.Item("User Defined Properties").Item("Document number").Value
TextBox1.Value = CStr(oRow.Item(a).Value)
TextBox2.Value = oModel.DisplayName
TextBox3.Value = CStr(oRow.Item(d).Value)
TextBox4.Value = CStr(ProjNum & oDocNum & "-" & ItemNum)
TextBox5.Value = CStr(oSheetMetalCompDef.ActiveSheetMetalStyle.Material.Name _
& " " & oSheetMetalCompDef.ActiveSheetMetalStyle.Thickness)
f = f + 1
oModel.Close (False)
Set oSheetMetalCompDef = Nothing
Set oModel = Nothing
Exit Sub
Else
MsgBox ("File Path Not Present - Check Parts List Type")
f = f + 1
Exit Sub
Else
f = f + 1
If f <= i Then
GoTo NextRow
Else
cmdOk.Enabled = False
Exit Sub
Else
f = f + 1
If f <= i Then
GoTo NextRow
Else
Exit Sub
Else
MsgBox ("Check Parts List Type")
Exit Sub
End Sub
Note: If I take out the material AND the thickness it works fine (Textbox5)
Without having a reproducable case I'm not sure what specific problem you're
running into. I created a test case that I think is similar to what you
have. Here's a modified version of your code and the files I used are
attached.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oPartsList As PartsList
Set oPartsList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
Dim oRow As PartsListRow
For Each oRow In oPartsList.PartsListRows
' Make sure we're only using visible rows.
If oRow.Visible Then
If oRow.Item("Part Type") = "Sheet Metal" Then
' Get the sheet metal document.
Dim oSMDef As SheetMetalComponentDefinition
Set oSMDef =
oRow.ReferencedRows.Item(1).BOMRow.ComponentDefinitions.Item(1)
Dim oSMDoc As PartDocument
Set oSMDoc = oSMDef.Document
Dim ProjNum As String
Dim DocNum As String
Debug.Print CStr(oSMDef.ActiveSheetMetalStyle.Material.Name
_
& " " & oSMDef.ActiveSheetMetalStyle.Thickness)
Next
End Sub
Brian Ekins
Thank you. It is what I needed as far as accessing the part from the partslist. I changed that in my code and it works great.
Technology Administrators
