Zooming to a location in a drawing
nbonnett-murphy
nbonnett-murphy
Hello, I have an iLogic script that is used for checking balloons for overrides. It loops through each sheet, then each balloon on the sheet and if it finds an override it will pop up a message box to let the user know.
I'm trying to add some functionality so that it will zoom to the location of the overriden balloon so that the user can get a look to review without needing to exit and restart the script. Here's what I have right now:
					oBalloon.Parent.Activate 'goes to corresponding sheet
					ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomAllCmd").Execute
					ThisApplication.ActiveView.Update()
					oDoc.SelectSet.Clear
					oDoc.SelectSet.Select(oBalloon)
'					ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomSelectCmd").Execute
'					ThisApplication.ActiveView.Update()
This is mostly working, it takes you to the sheet and selects the balloon (or balloon set). What I'd really like though, is to zoom to the balloon itself. I've tried several variations of the last 2 lines, but I haven't gotten anything to work yet. I tried using execute2(true), all the various "AppZoom..." commands I could find, declaring a global command manager object etc.
Does anyone know how I can zoom to a selected object in a drawing? If I could even get windowzoom to work programmatically I could get the coords of the bubble and then set an offset for the selection, but I haven't been able to figure that out either.
dalton98
The only way i can think of then is to zoom to the specific point of the balloon. ex
Dim oSheet As Sheet = ThisDoc.Document.ActiveSheet
Dim oBalloon As Balloon = oSheet.Balloons(1)
Dim oPoint As Point = ThisApplication.TransientGeometry.CreatePoint(oBalloon.Position.X, oBalloon.Position.Y, 0)
Dim oCam As Camera = ThisApplication.ActiveView.Camera
oCam.Target = oPoint
oCam.SetExtents(5, 5)
oCam.Apply
nbonnett-murphy
Thanks for the help! I'm about to leave for the day but I'll give it a shot tomorrow. I didn't realize that you could also use the camera movement stuff in a drawing as well as a part/assembly, so I haven't dug into it at all yet. The "transientGeometry" thing looks useful as well.
Curtis_Waguespack
Hi @nbonnett-murphy
See this link to a previous post on this topic:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-find-baloon-and-zoom-contains...
I hope this helps.
Curtis
nbonnett-murphy
This is perfect, thanks very much. I had a really hard time finding the right search terms without getting flooded by answers that were almost what I needed.
I just needed to add a
to make sure that I got to the right sheet.
