ONSave Event not being triggered unless breakpoint is set
cstaley
cstaley
I have an addin that does some additional processing on save of a drawing.  The whole thing is working great in my development environment.  On a client machine, my onSave code is not being run.  I tried installing Visual Studio on the client and the only time I can hit my onSave code is if I set a breakpoint on the line in Activate where the event is registered.  I have a log entry right after the registration, so I can see that the code is getting there, but can't figure out why the registration doesn't happen without a breakpoint.
Here is the event registration:
public void Activate(ApplicationAddInSite addInSiteObject, bool firstTime)
_inventorApp = addInSiteObject.Application;
Buttons.invButton.InventorApplication = _inventorApp;
_inventorApp.ApplicationEvents.OnSaveDocument += new ApplicationEventsSink_OnSaveDocumentEventHandler(onSaveEvent); //I need a breakpoint here in order to get to the event code
GenUtils.Logger.WriteLine("OnSave Event handler registered");
ControlDefinitions ctrlDefs = _inventorApp.CommandManager.ControlDefinitions;
etc....
Here is my event handler:
private void onSaveEvent(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
GenUtils.Logger.WriteLine("OnSave Event handler triggered");
if (BeforeOrAfter == EventTimingEnum.kAfter)
Document doc = Addin._inventorApp.ActiveDocument;
if (doc.DocumentType == DocumentTypeEnum.kDrawingDocumentObject)
InventorHelper.DoXML();
HandlingCode = HandlingCodeEnum.kEventNotHandled;
Any ideas?
Michael.Navara
You need to keep reference to the ApplicationEvent as long as the addin is active. I keep this reference in field at the addin class level
[Guid("C0717AA7-C127-4AAD-8290-34353FA2511B")]
public class MyAddIn : ApplicationAddInServer
    private Application inventor;
    private ApplicationEvents applicationEvents;
        inventor = addInSiteObject.Application;
        applicationEvents = inventor.ApplicationEvents;
        applicationEvents.OnSaveDocument += ApplicationEvents_OnSaveDocument;
    public void Deactivate()
        applicationEvents.OnSaveDocument -= ApplicationEvents_OnSaveDocument;
        applicationEvents = null;
        inventor = null;
        GC.Collect();
        GC.WaitForPendingFinalizers();
    public void ExecuteCommand(int commandId)
    public object Automation => null;
    private void ApplicationEvents_OnSaveDocument(_Document documentObject, EventTimingEnum beforeOrAfter, NameValueMap context, out HandlingCodeEnum handlingCode)
        //TODO: Handle save event here
        handlingCode = HandlingCodeEnum.kEventNotHandled;
cstaley
That did the trick.  Thanks!
