Zoom to view in drawing:
Mike.Wohletz
Message 1 of 13
Mike.Wohletz
I have a program that either cycles through all the base views of a drawing or works with a selected view and pushes properties that I need in the drawing file back to the part or assembly file, currently I am showing what view is being edited by selecting it so that it shows up with this:
{code}
oDoc.SelectSet.Select(oView)
{code}
This gives the user an idea of what is going on at that time and if they need to include or exclude any information. My question is how can I zoom to that view rather than selecting it since it can be hard to see the little dotted selection line of a view.
Replies (12)
Message 2 of 13
Try the following macro. Select a drawing view before running it.
Sanjay-
Sub ZoomToDrawingView()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDrawingView As DrawingView
Set oDrawingView = oDoc.SelectSet.Item(1)
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oView As View
Set oView = ThisApplication.ActiveView
Dim oCamera As Camera
Set oCamera = oView.Camera
Dim oEyePt As Point
Set oEyePt = oTG.CreatePoint(oDrawingView.Center.X,
oDrawingView.Center.Y, oCamera.Eye.Z)
oCamera.Eye = oEyePt
Dim oTargetPt As Point
Set oTargetPt = oTG.CreatePoint(oDrawingView.Center.X,
oDrawingView.Center.Y, oCamera.Target.Z)
oCamera.Target = oTargetPt
Call oCamera.SetExtents(oDrawingView.Width * 2, oDrawingView.Height * 2)
oCamera.Apply
End Sub
Message 3 of 13
I just had an interesting thought. What if you could SetExtents based the view and all annotations (or other geometry if applicable) associated to the view. In other words, calculate a tight box around everything associated to that view. Starting with the view as the parent, can I loop through all its child objects (I'm assuming 2d geometry of the model) and then any associated annotations. I would need to somehow be able to calculate a rangebox (may have to be a Collection of Box2d) of where each object exists in sheet space. iterate through all those rangebox to figure a min X, max X min Y & max Y (i.e. a rangebox containing all geometry associated to the view).
Message 4 of 13
Yes, that would be useful. and would be possible to do in the way that you
outlined (most drawing objects now support a RangeBox property). There are
still a few annotations that the API doesn't support (welding symbols,
etc.) - but not too many.
Sanjay-
Message 5 of 13
Can you get me started? Looking at the View object, I can't see a Property that leads me to the 2D geometry on the View. Also, how do I obtain object associated to views like balloons, dimensions, etc (i.e. parent child relationship)?
Message 6 of 13
A view in a drawing is represented by a DrawingView object. However,
annotations (such as notes, balloons, etc.) are on the Sheet object. You'd
have to iterate over the annotations on a sheet and filter out the ones that
are associated with a drawing view. The process to get the associated view
is, unfortunately, different for each annotation. For a balloon,
Balloon.ParentView provides that information. But for other annotations,
you'll need to drill down to the geometry they attach to and hence get to
the associated view.
Sanjay-
Message 7 of 13
Ok but I need a little more detail. I can't see how to drill down. Can you give me one short example (pseudo code)? I'm looking at the members of the GeneralDimension for instance and I can't tell which member contains the data I need. Even if I did know, whats the data's name that gets me the associated view?
Message 8 of 13
All I need is a nudge in the right direction. I've been poking around the API and can't see the realtionship bewteen and Annotation and its View.
Message 9 of 13
Sorry I haven't been following this thread, but from what you say here, I
would suspect if you stepped up the Parent structure of the annotation you
would eventually get to the view. ie.... oannotation.parent.parent.....etc.
KWiKMcad
Kent Keller
"Cadfish1" wrote in message news:[email protected]...
Message 10 of 13
Consider the case of a linear general dimension.This is represented by the
LinearGeneralDimension object (which derives from GeneralDimension). The
following will return the first drawing curve (DrawingCurve object) that the
dimension is attached to: LinearGeneralDimension.IntentOne.Geometry.
Finally, DrawingCurve.Parent returns the drawing view that contains this
curve.
You'll need to similarly special case each annotation.
Sanjay-
Message 11 of 13
Thanks Sanjay & Kent.
Message 12 of 13
kiruba
Thanks Sanjay,
i was stuck at this stage while attempting drawingview.camera.saveasbimap. It was giving "not implemented" error; your solution has given a workaround.
Digital Automation in Design Transformation
Message 13 of 13
miechh
The given solution works for me as well! Thanks!
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 11 Professional (64bit)
