xml error's
xml error's
xml error's
HI,
Migrating from Inventor 2012 to 2014 my templates give the errorin the JPG attached, but the files that is giving the error are in the templates folder so I don't have the "slidest clue" of whats happening...
TIA
FG
JamesNordgren
My guess is that the problem is with your project file.  Open the project editor, and make sure under the 'Folder Options' that the path to the templates and design data is pointed to the new 2014 folder created when you installed 2014.
If you are using Windows7, I beleive the default install location is C:\Users\Public\Documents\Autodesk\Inventor 2014.
Hope that helps
James
