Write out all appearance information to a file. API Sample
C-Hoppen
C-Hoppen
I tried to translate the API sample to .net (c#). Code snippet:
            Inventor.AssetLibraries libraries;
            libraries = oApp.AssetLibraries;
            foreach (Inventor.AssetLibrary assetLib in libraries)
                output.Add("Library " + assetLib.DisplayName);
                output.Add("  DisplayName: " + assetLib.DisplayName);
                output.Add("  FullFileName: " + assetLib.FullFileName);
                output.Add("  InternalName: " + assetLib.InternalName);
                output.Add("  IsReadOnly: " + assetLib.IsReadOnly);
                foreach (Inventor.Asset appearance in assetLib.AppearanceAssets)
                    output.Add("    Appearance");
                    output.Add("      DisplayName: " + appearance.DisplayName);
                    output.Add("      Category: " + appearance.Category.DisplayName);
                    output.Add("      HasTexture: " + appearance.HasTexture);
                    output.Add("      IsReadOnly: " + appearance.IsReadOnly);
                    output.Add("      Name: " + appearance.Name);
                    foreach (Inventor.AssetValue value in appearance)
                        PrintAssetValue(value, 8);
The oApp.AssetLibraries collection contains only one empty library "Favourites" . No matter if a document is open or not. Tested with ....inventor.interop.dll V. 18.
Any help would be great.
Christoph
YuhanZhang
Can you double check in UI if there are other libraries? You can check it in the Appearance/Material Browser, if there is only the Favourites?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
C-Hoppen
yuhanzhang,
it depends on whether a document is opend or not. I need to read appearances when no document is opend. This seems not to be possible.
When a part or assm. is opened, I can read 4 libs.
Christoph
YuhanZhang
Seems if you just launch Inventor and without openning any document the asset libraries will not be loaded except the Favourites. I logged this issue as 33516 in our TFS, please provide this No. to get its status.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
YuhanZhang
I think you can workaround this issue with below VBA sample:
Sub LoadAssetLibs()
    Debug.Print ThisApplication.AssetLibraries.Count
    Dim olib As AssetLibrary
    For Each olib In ThisApplication.AssetLibraries
        Debug.Print olib.DisplayName
    Next
    Dim oDP As DesignProject
    Set oDP = ThisApplication.DesignProjectManager.ActiveDesignProject
    Dim oPAL As ProjectAssetLibrary
    For Each oPAL In oDP.AppearanceLibraries
        Call ThisApplication.AssetLibraries.Open(oPAL.LibraryFilename)
    Next
    For Each oPAL In oDP.MaterialLibraries
    Next
    Next
End Sub
 Hope this helps.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
C-Hoppen
Thanks a lot!
Christoph
