Just recovered this from google cache:
Sub Main()
If Not ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
Messagebox.Show("Current document is not drawing docuemnt", "Inventor")
Exit Sub
End If
Dim value_List As List(Of String) = New List(Of String)
value_List.Add(iProperties.Value("Project", "Vendor"))
value_List.Add( iProperties.Value("Project", "Stock Number"))
value_List.Add(iProperties.Value("Project", "Project"))
value_List.Add(iProperties.Value("Project", "Designer"))
Dim oDoc As Document
oDoc = ThisDrawing.ModelDocument
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Update_Properties(oDoc, value_List)
Dim oAsyDoc As AssemblyDocument
oAsyDoc = oDoc
Dim oReferDoc As Document
Dim occ As ComponentOccurrence
Dim oDef As AssemblyComponentDefinition
oDef = oAsyDoc.ComponentDefinition
For Each occ In oDef.Occurrences
If occ.SubOccurrences.Count = 0 Then
oReferDoc = occ.ReferencedDocumentDescriptor.ReferencedDocument
Update_Properties(oReferDoc, value_List)
Else
processAllSubOcc(occ, value_List)
End If
Next
Else If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
End If
End Sub
Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence , value_List As List(Of String))
Dim oSubCompOcc As ComponentOccurrence
For Each oSubCompOcc In oCompOcc.SubOccurrences
If oSubCompOcc.SubOccurrences.Count = 0 Then
oReferDoc = oSubCompOcc.ReferencedDocumentDescriptor.ReferencedDocument
Update_Properties(oReferDoc,value_List)
Else
Update_Properties(oReferDoc ,value_List)
Call processAllSubOcc(oSubCompOcc, value_List)
End If
Next
End Sub
Sub Update_Properties(oDoc As Document, value_List As List(Of String))
oDoc.PropertySets.Item("Design Tracking Properties").Item("Vendor").Value = value_List.Item(0)
oDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value = value_List.Item(1)
oDoc.PropertySets.Item("Design Tracking Properties").Item("Project").Value = value_List.Item(2)
oDoc.PropertySets.Item("Design Tracking Properties").Item("Designer").Value = value_List.Item(3)
oDoc.Save()
End Sub
