Would you use C# or C++ for a new project?
oransen
oransen
If you have a new project to do which does not require a presumable speed/memory advantage of C++ over C#, would you use C# or C++?
I don't think the project requires any advanced processing which C++ could give, so I'm tempted by C#, even though I have a lot of support functions written for my Inventor in C++ book.
Hmmmm.
pball
Of the two listed I'd go with C#. Assuming this is for an Inventor related project, finding examples and documentation in C# is more likely.
Though personally I use VB since most of the official API examples are in VB. That and a large portion of the code posted on the forums is either VBA macro code, iLogic code (based on VB), or straight VB code.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
oransen
"finding examples and documentation in C# is more likely"
Apart from what I wrote myself:
Inventor Programming in C++
But I agree with you
floccipier
http://www.ransensoftware.com/Inventor-CPP/
Thanks for this, have been using your work for reference and learning for so long.
