WorkPoints AddWorkPointByPlaneAndAxis?
oransen
oransen
Maybe I'm missing something,but I can't find a function called something like:
WorkPoints.AddWorkPointByPlaneAndAxis?
Is there one? The point would be created at the intersection of a plane and an axis...
oransen
I did try it usingWorkPoints.AddByCurveAndEntity but I don't have any sketch lines available, only WorkAxis and WorkPlane. It seems that the first parameter...
This object can be an edge or a 2d or 3d sketch entity.
...which I don't have.
HermJan.Otterman
Hello Oransen,
you where close,
look at my code, it will create the workpoint:
Private Sub CreatePoint()
Dim oPartDoc As PartDocument = Thisapplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oAxis As WorkAxis = oCompDef.WorkAxes(5)
Dim oWorkPlane As WorkPlane = oCompDef.WorkPlanes(4)
Dim oWPt As WorkPoint = oCompDef.WorkPoints.AddByCurveAndEntity(oAxis, oWorkPlane)
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
oransen
Thanks for your reply HermJan, I had to do it in C++ and got an solution close to yours...
        // Get the proxy of the axis
        CComPtr<WorkAxisProxy> pNodeWAZProxy ;
        ZAxisArray[1]->get_Item(2,(IDispatch**)&pNodeWAZProxy);
        CComPtr<TransientGeometry> pTransGeom = theApp.GetTransGeomPtr () ;
        LinePtr pLine = pNodeWAZProxy->GetLine();
        PointPtr pLineRoot = pLine->GetRootPoint();
        UnitVectorPtr pLineDir = pLine->GetDirection();
        CComPtr <Vector> pvecDir  ;
        hRes = pLineDir->AsVector(&pvecDir);
        if (FAILED(hRes)) {
            gLogger.Printf(ekErrMsg, "Could not get AsVector");
            return;
        CComPtr <Line> pZAxis;
        hRes = pTransGeom->CreateLine  (pLineRoot,pvecDir,&pZAxis);
        if (FAILED(hRes)) {
            gLogger.Printf(ekErrMsg, "Could not CreateLine");
            return;
        CComPtr<Point> pOrigin;
        CComPtr<Point> p1;
        CComPtr<Point> p2;
        pTransGeom->CreatePoint(0, 0, 0, &pOrigin);
        pTransGeom->CreatePoint(1, 0, 0, &p1);
        pTransGeom->CreatePoint(0, 1, 0, &p2);
        CComPtr<Plane> pGeomXYPlane;
        hRes = pTransGeom->CreatePlaneByThreePoints(pOrigin, p1, p2, &pGeomXYPlane);
        if (FAILED(hRes)) {
            gLogger.Printf(ekErrMsg, "Could not CreatePlane");
            return;
        CComPtr <ObjectsEnumerator> pObjEnum;
        hRes = pTransGeom->CurveSurfaceIntersection(pZAxis, pGeomXYPlane, 0.1, &pObjEnum);
        if (FAILED(hRes)) {
            gLogger.Printf(ekErrMsg, "Could not surface intersection");
            return;
        TRACE ("There are %d intersections...\n",pObjEnum->Count);
        if (pObjEnum->Count < 1) {
            gLogger.Printf(ekErrMsg, "No intersections found...");
            return;
        CComPtr <Point> pIntersectionPoint;
        hRes = pObjEnum->get_Item(1,(IDispatch**)&pIntersectionPoint);
        if (FAILED(hRes)) {
            gLogger.Printf(ekErrMsg, "Could not get intersection point");
            return;
        TRACE("Intersection at %.2f %.2f %.2f \n",
              pIntersectionPoint->GetX(),
              pIntersectionPoint->GetY(),
              pIntersectionPoint->GetZ());
        CComPtr<WorkPoints> pWorkPoints;
        hRes =pAssemblyCompDef->get_WorkPoints(&pWorkPoints);
        if (FAILED(hRes)) {
            gLogger.Printf(ekErrMsg, "Could not get work points");
            return;
        CComPtr <WorkPoint> pInterWorkPoint;
        pWorkPoints->AddFixed (pIntersectionPoint,FALSE,&pInterWorkPoint);
        if (FAILED(hRes)) {
            gLogger.Printf(ekErrMsg, "AddFixed point failed");
            return;
        CComBSTR bstrPointName("ZeroPoint");
        hRes = pInterWorkPoint->put_Name(bstrPointName);
        if (FAILED(hRes)) {
            return;
Lots of error checking and C++ is more verbose than VB, but it is like your solution...
