Get model dimensions using Inventor API or iLogic
Hi All,
I'm trying to get the dimensions (length, breadth, height) of all the models referenced in an assembly. I'm planning to do this using either Inventor API or Apprentice API reading the BOM of the main assembly and opening each model in Inventor and executing something similar to the below code (source from Justin's reply in this thread - https://forums.autodesk.com/t5/inventor-customization/measure-extentslength-from-a-part-to-drawings/...).
var compDef = assemblyDoc.ComponentDefinition;
var rangeBox = compDef.RangeBox;
MessageBox.Show("Unit is " + assemblyDoc.UnitsOfMeasure.GetStringFromType(assemblyDoc.UnitsOfMeasure.LengthUnits));
//to do: make changes based on units
//by default the values are in cm, convert to inches
var length = (rangeBox.MaxPoint.X - rangeBox.MinPoint.X) / 2.54;
var width = (rangeBox.MaxPoint.Y - rangeBox.MinPoint.Y) / 2.54;
var height = (rangeBox.MaxPoint.Z - rangeBox.MinPoint.Z) / 2.54;
MessageBox.Show(length + Environment.NewLine + width + Environment.NewLine + height);
But when I run the below ilogic rule on random models to check the output, for some models some dimensions differ by 1 or 2 inches
SyntaxEditor Code Snippet
MessageBox.Show(Measure.ExtentsLength, "Length")
MessageBox.Show(Measure.ExtentsWidth, "Width")
MessageBox.Show(Measure.ExtentsHeight, "Height")
Model1:
program (in)iLogic (in)
35.8334.8643055
32.81727.3675394
9696
Model 2:
18.750418.75
16.76816.7287
3.8282.9295
My questions are:
1. Why this difference in dimensional values? I checked the work features on these models, they were turned off.
2. Is there a better solution for my original problem? Get the dimensions (length, breadth, height) of all the models referenced in an assembly.
Rekha.
b_sharanraj
Hi @Anonymous
Is it possible to upload your model?
Regards
B.Sharan Raj
b_sharanraj
The values which you got by iLogic will be the right one.
I can see that via program you are trying to measure the Length, Width & Height of parts in assembly itself.
Try by opening each part from assembly and measure the Length, Width & Height of Active Document. Then compare the values with iLogic it'll match.
Regards
B.Sharan Raj
