Workpoint - create with coords and name
MarkyTomm
MarkyTomm
Hi All,
Just looking for a vba code snippet to create a workpoint within an already open part file.
The point will have x, y and z coords which i believe is this piece of code
Dim wp As WorkPoint
Set wp = oCompDef.WorkPoints.AddFixed(ThisApplication.TransientGeometry.CreatePoint(xValue, yValue, zValue))
Can anyone help me with assigning a custom browser name to the point other than the default "Work Point1" please?
Regards
Mark
Inventor pro 2020
Sergio.D.Suárez
Hi, try the following code in VBA. It is to add the WorkPoint and rename it.
Sub CreateWorkPoint()
    Dim doc As PartDocument
    Set doc = ThisApplication.ActiveDocument
    Dim oCD As PartComponentDefinition
    Set oCD = doc.ComponentDefinition
    Dim wp As WorkPoint
    Set wp = oCD.WorkPoints.AddFixed(ThisApplication.TransientGeometry.CreatePoint(1, 2, 3))
    wp.Name = "My_WorkPoint"
End Sub
In ilogic rule
    Dim wp As WorkPoint
I hope this helps with your work
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
MarkyTomm
Hi Sergio,
Thanks for your reply.
That is what i thought it should be and initially had it coded using the .name property but it throws a runtime error
"Method 'Name' of object 'Workpoint' failed"
I have found a workaround where by I rename all the points after they have all been created which for some reason works, but it is a bit of a hack as i would like to name them at point of creation
Any other thoughts?
Regards
Mark
Sergio.D.Suárez
Hi, the code shared above is a basic code. If you want to add more than one point the rule will throw error because you cannot create another point with the same name of a previously created point.
Try the following code
    Dim i As Integer
    i = 1
    Dim oWP As WorkPoint
    For Each oWP In oCD.WorkPoints
        If InStr(oWP.Name, "My_WorkPoint") <> 0 Then
        i = i + 1
    Next
    Set oWP = oCD.WorkPoints.AddFixed(ThisApplication.TransientGeometry.CreatePoint(1, 2, 3))
    oWP.Name = "My_WorkPoint_" & i
End Sub
Mechanical Designer
fullevent
Hello @Sergio.D.Suárez,
didn't try but should be
If InStr(oWP.Name, "My_WorkPoint_" & i ) <> 0 Then
right? 🤔
Greetings
Aleksandar Krstic
Produkt- und Projektmanager
