Apprentice Camera Save As JPG - Error
ianjwellings
ianjwellings
I'm trying to save a camera view of a model as a jpg.
I've used these articles to produce my code:
https://modthemachine.typepad.com/my_weblog/training-material/
https://modthemachine.typepad.com/my_weblog/2013/09/working-with-cameras-part-2.html
But I keep getting this error:
Unspecified error (Exception from HRESULT: 080004005 (E_FAIL)
This is my code, any help would be greatly appreciated:
Inventor.ApprenticeServerComponent oApprentice;
Inventor.ApprenticeServerDocument oApprenticeDoc;
Inventor.Camera oCamera;
oApprentice = new Inventor.ApprenticeServerComponent();
oApprenticeDoc = oApprentice.Open(@"C:\Inventor\eye004.ipt");
oCamera = oApprentice.TransientObjects.CreateCamera();
oCamera.SceneObject = oApprenticeDoc.ComponentDefinition;
oCamera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopRightViewOrientation;
oCamera.Fit();
oCamera.ApplyWithoutTransition();
oCamera.Apply();
TransientObjects oTo = oSvr.TransientObjects;
Inventor.Color oTopColor = oTo.CreateColor(255, 0, 0);
Inventor.Color oBottomColor = oTo.CreateColor(255, 255, 255);
oCamera.SaveAsBitmap("C:\\Temp\\eye004.jpg", 800, 600, oTopColor, oBottomColor);
chandra.shekar.g
Autodesk Support
Autodesk Support
@ianjwellings,
At glance, it shows that error is due to incompatibility of platform (x86). I am guessing that code is built on x86 platform. As Inventor 2019 removed to support for 32 bit platform, it is advised to use x64 bit platform to build code. Hoping that attached changes(64 bit.png) might help to fix the issue.
Please feel free to contact if there are any queries.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
sundaram1087
Hi
I try to Export image using Apprentice method. As suggested i have update the X64 in the compile option
Still am not able to get the image using that method
Am getting the following error
Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
Regards
Shunmugasundaram
Hi
I have the same error, attached image of the code
regards
ls-4453
This still happens in Inventor 2022. Is there any solution?
ls-4453
Bump. Can someone from Autodesk reply?
