Wierd Problem with what seems to be simple code
Hello,  I am working with Inventor 2014 and am very new to programing,  I have been making some code to auto output some information so we do not need to enter it manually.  One part of the program is to detect if the length of the part is in inches or mm and to record the length appropriately.
How I do this is I measure its length to 5 decimal places in mm ( this is all that is needed, and should prevent any small rounding errors from inventor ) then divide this by 25.4 and times by 16.  Essentially if this is a hole number it is inches and if it is not it is mm.
The problem I have is that it seems to work randomly.  For example 3.5", 3", 13.0625", 33" all wont work but 3.75", 3.0625", 40", 2.5", 12.5", 12.0625" Will work.   If someone could please shed some light on what I am doing wrong, or if they have a work around it would be much appreciated.
Thank you!
Dim xxLength As String
If Round(Measure.ExtentsHeight,5)/25.4*16 = Round(Measure.ExtentsHeight/25.4*16,0) Then
	xxLength = RoundToFraction(Measure.ExtentsHeight/25.4, 1/16, RoundingMethod.Round).Replace(" ", "-") & Chr(34)
Else
	xxLength = Round(Measure.ExtentsHeight,1) & " mm"
MessageBox.Show(xxLength, "Title")
Just adding to the last post I tried INT() command instead as well as a set mm value of 76.2mm (3") and I have the same problem, put in 101.6mm (4") and it works, really no idea what I am doing worng
'Dim xHeight As Double = Round(Measure.ExtentsHeight,5)/25.4*16
Dim xHeight As Double = 76.2/25.4*16
If xHeight= Int(xHeight) Then
	xxLength = RoundToFraction(xHeight/16, 1/16, RoundingMethod.Round).Replace(" ", "-") & Chr(34)
Else
MessageBox.Show(xxLength & "     initial = " & xHeight, "Title")
I found a work around but if anyone can still explain to me what I did wrong it would be appreciated.  I'm assuming it has something to do with how the values are actually rounded. Thank you again for taking the time to look at my problem!
'Dim xHeight As Double = 76.2/25.4*16
If xHeight-Int(xHeight)<.000001 Then
Else
JelteDeJong
Comparing doubles is always tricky. You might want to look at the DoubleForEquals.IsEqual(...) function. Your function would look something like this.
Dim xHeight As Double = 101.6/25.4*16
If DoubleForEquals.IsEqual( xHeight, Int(xHeight)) Then
Else
I wrote a post "Unexpected Results" which might interest you.
Also, there is a post about converting values. There are some built-in functions that can help you. "Parameter, Document and Database Units"
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you very much for the response and detailed information.  I had a read over the information you supplied, and tried out the code you wrote and it works perfect.  Thank you again!
