Swapping Content Center parts from parameters
alan.wedge
alan.wedge
I have a content center part with multiple variations. I want to change between different variations using parameters and a linked Excel document.
I know how to write the logic to work out what is needed, I just need to know how to switch out the parts or if it is even possible.
Alan.
A.Acheson
Here is an image of how to use  the ilogic capture snippet tool. If you use the origins planes/points/axis as much as possible when constraining you can keep key constraints when switching members. I would think add and delete should work for you.
You can also use the API but it does take a lot more lines and knowledge of the functions.
Here is a post here
If you have more questions please post some images and a description of the workflow and which section you need assistance with.
Regards
Alan
alan.wedge
Thanks for the help, I ended up finding a different solution.
Using the IPart rather than the content center part means I can use the following:
partname = "part"
rowname = "config1"
iPart.ChangeRow(partname,rowname)
the part name is looking in the tree for the object name, the row name is looking for the file name of the IPart table
I can drive this by using something like:
rowname = "config" & parameter
