Why this rule does not to run?
38620079
Message 1 of 8
38620079
HI,I don't know how to make this rule work below the code, who can tell me what to do?
Thanks!
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim osubdoc As Document
Dim opropset As Inventor.PropertySet
Dim icount As Long
For Each osubdoc In oDoc.AllReferencedDocuments
opropset = osubdoc.PropertySets.Item(4).Item 'User DefinedProperties
icount = opropset.Count
If icount>0 Then
For i = icount To 1 Step -1
On Error Resume Next
opropset.Item(i). Delete
Err.Clear
Next
Next
Replies (7)
Message 2 of 8
A.Acheson
Hi @38620079
You have incorrectly set the Property Set.
Working code
Dim icount As Long
	opropset = osubdoc.PropertySets.Item(4) 'User DefinedProperties
	If icount>0 Then
			opropset.Item(i).Delete
			Err.Clear
		Next
Next
and here is a shorter version of the same without indexing and with a check for modifiable files ( skip Read only files such as Content center and Library files)
Dim oDoc As Document = ThisApplication.ActiveDocument
For Each osubdoc As Document In oDoc.AllReferencedDocuments
	If osubdoc.IsModifiable Then
		Dim opropset As Inventor.PropertySet = osubdoc.PropertySets.Item(4)
		For Each prop As Inventor.Property In opropset
			prop.Delete
		Next
Next
Regards
Alan
Message 3 of 8
38620079
thank you! but i want to do that
Message 4 of 8
A.Acheson
This screenshot is from VBA object model editor.
Are you using VBA or ilogic\VB.Net launguage?
The code you provide originally is for ilogic\VB.Net launguage and the revised code is written for their also.
Regards
Alan
Message 5 of 8
38620079
is Ok thanks
Message 6 of 8
A.Acheson
Yes this code here will do exactly that, loop over all custom iproperties and delete. If it does not work please provide a screenshot of errorbmessages.
			prop.Delete
		Next
Next
Regards
Alan
Message 7 of 8
38620079
I am wrong,I use rules to run in part, not in assembly.
Message 8 of 8
A.Acheson
Here it is to delete custom iprop per document, run as an external rule
Dim opropset As Inventor.PropertySet = oDoc.PropertySets.Item(4)
   prop.Delete
Next
Regards
Alan
