why keyboardevents NOT working?
liminma8458
liminma8458
In an InteractionEvents,  I try to use a keyboardevents at same time with a selectionevents. So while in doSelectEvents_OnPreSelect process, the user can click keyboard (such as space bar, or esc key) to invoke some action. But the code does not work out. Both oKeyPress_OnKeyDown() and oKeyPress_OnKeyPress() have no response. Can somebody try it out and see why?
The code in class is as attached. The code in module is :
Public Sub keyboard_enter_test()
Dim oEdge As Edge
Dim oSelect As New Clsselect_edge_keyboard
Set oEdge = oSelect.Pick(kPartEdgeCircularFilter, "Select a circular edge:")
End Sub
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
laszlo_nagy
Hi!
When you run the process from VBA Editor, I don't know why but the KeyboardEvents are not active Until you click or Pan the model window
try to add this line into you class it works for me
*Ps sorry for my english
----------Class --------------
' Set the filter using the value passed in.
oSelectEvents.AddSelectionFilter filter
' Start the InteractionEvents object.
oInteractEvents.Start
'ADD THIS LINE
AppActivate ThisApplication.Caption
' Loop until a selection is made.
Do While bStillSelecting
DoEvents
Loop
liminma8458
Work perfectly.
Thank you so much!!!
Limin
