Creating Sketch Line on 2d Drawing Using AddByTwoPoints
Tiffany_Hayden_
Message 1 of 16
Tiffany_Hayden_
Hello. I found this bit of code and tried modifying it to my needs. I'm not sure what I'm missing but it doesn't seem to work. I'm not sure if I'm using GeomIntent Correctly. My workflow is below. Thanks for your help!
WorkPoints
WorkPointProxY
Create Sketch
Edit Sketch
Center Marks
CenterMarks to WorkPointProxy
Geometry Intent
CreatePoint2D
Create Line
Constrain Line
                        'Get the first two work points (WorkPoints.Item(1) is the origin)
                        Dim oWorkPoint1 As Inventor.WorkPoint
                        Dim oWP2 As Inventor.WorkPoint
                        Set oWorkPoint1 = GetDocWPt(oSubOcc.Definition.Document, "Center Point")
                        Set oWP2 = GetDocWPt(oSubOcc.Definition.Document, "POINT FLOOR OUT")
                        'Create a proxy for the two work points
                        Dim oWorkPointProx1 As Inventor.WorkPointProxy
                        Dim oWorkPointProx2 As Inventor.WorkPointProxy
                        Call oSubOcc.CreateGeometryProxy(oWorkPoint1, oWorkPointProx1)
                        Call oSubOcc.CreateGeometryProxy(oWP2, oWorkPointProx2)
''                        'Include the work points in the drawing view
'                        Call oView.SetIncludeStatus(WorkPointProx1, True)
'                        Call oView.SetIncludeStatus(oWorkPointProx2, True)
'                        oView.SetVisibility oWorkPointProx1, False
'                        oView.SetVisibility oWorkPointProx2, False
                        Dim oDrawingSketch As DrawingSketch
                        Dim oLine As SketchLine
                        Set oDrawingSketch = oView.Sketches.Add
                        Call oDrawingSketch.Edit
                        'Now we need to find the two centermarks that represent the work point proxies
                        Dim oCenterMark1 As Inventor.Centermark
                        Dim oCenterMark2 As Inventor.Centermark
                        Dim oCenterMark As Inventor.Centermark
                        For Each oCenterMark In oSheet.Centermarks
                            If oCenterMark.Attached Then
                                If oCenterMark.AttachedEntity Is oWorkPointProx1 Then
                                    Set oCenterMark1 = oCenterMark
                                ElseIf oCenterMark.AttachedEntity Is oWorkPointProx2 Then
                                    Set oCenterMark2 = oCenterMark
                        Next
                        Dim oTG As TransientGeometry: Set oTG = ThisApplication.TransientGeometry
                        'From the two work points, we create the geometry intent
                        Dim oGeomIntent1 As Inventor.GeometryIntent
                        Dim oGeomIntent2 As Inventor.GeometryIntent
                        Set oGeomIntent1 = oSheet.CreateGeometryIntent(oCenterMark1, Inventor.kPoint2dIntent)
                        Set oGeomIntent2 = oSheet.CreateGeometryIntent(oCenterMark2, Inventor.kPoint2dIntent)
                        Dim oPointOne As Point2d
                        Set oPointOne = oTG.CreatePoint2d(oGeomIntent1.PointOnSheet.X, oGeomIntent1.PointOnSheet.Y)
                        Dim oPointTwo As Point2d
                        Set oPointTwo = oTG.CreatePoint2d(oGeomIntent2.PointOnSheet.X, oGeomIntent2.PointOnSheet.Y)
                        Dim oPointStart As Point2d
                        Set oPointStart = oView.SheetToDrawingViewSpace(oPointOne)
                        Dim oPointEnd As Point2d
                        Set oPointEnd = oView.SheetToDrawingViewSpace(oPointTwo)
                        Set oLine = oDrawingSketch.SketchLines.AddByTwoPoints(oPointStart, oPointEnd)
                        oLine.Construction = True
                        Call oDrawingSketch.GeometricConstraints.AddHorizontal(oLine)
Call oDrawingSketch.ExitEdit
Tiffany Hayden
Replies (15)
Message 2 of 16
yan.gauthier
Have you tried using oPointOne and oPointTwo instead ?
Message 3 of 16
Tiffany_Hayden_
@yan.gauthier  Yes. I still get this error saying oPoint1 and oPoint2 is nothing. I'm not sure why they are nothing. My Geom is nothing too in the Locals window. But it found something?
Tiffany Hayden
Message 4 of 16
yan.gauthier
I did a quick check and I think you could just use your centermark.PointOnSheet.X and centermark.PointOnSheet.Y instead ?
a Geometry intent would be required for you to create a centermark or an annotation, you don't need it to create a sketch element.
Cheers,
Message 5 of 16
Tiffany_Hayden_
Like this?
                        Set oPointOne = oTG.CreatePoint2d(oCenterMark1.PointOnSheet.X, oCenterMark1.PointOnSheet.Y)
                        Set oPointTwo = oTG.CreatePoint2d(oCenterMark2.PointOnSheet.X, oCenterMark2.PointOnSheet.Y)
                        Set oLine = oDrawingSketch.SketchLines.AddByTwoPoints(oPointOne, oPointTwo)
Tiffany Hayden
Message 6 of 16
yan.gauthier
yes and like this, you pointstart and pointend are not required
here is a macro i made to draw a vertical and an horizontal line to separate the folded view from the unfolded view at my job. After the macro run, the user may remove one or the other sketch. As long as there is still one of the sketch there, the macro won't fire again
Sub AddPliageLine(osheet As Sheet)
'Create vertical line and horizontal between titleblock edge and sheet border
Dim invapp As Inventor.Application
Dim oBorder As Border
Dim oTitleBlock As TitleBlock
Dim oLine As LineSegment
Dim oSketch As Sketch
Dim HighPoint As Point2d
Dim LowPoint As Point2d
Dim LeftPoint As Point2d
Dim RightPoint As Point2d
On Error GoTo AddPliageLineErr
Set invapp = ThisApplication
'Look for already existing sketch
For Each oSketch In osheet.Sketches
    If InStr(1, oSketch.name, "vertical", vbTextCompare) > 0 Or InStr(1, oSketch.name, "horizontal", vbTextCompare) > 0 Then
        Exit Sub 'Sketch already there, don't add another
Next oSketch
'Validate there is a title block
If Not osheet.TitleBlock Is Nothing Then
    Set oTitleBlock = osheet.TitleBlock
Else
    MsgBox "Le dessin doit contenir un cartouche", vbMsgBoxSetForeground, "AddDecoupeLine"
    Exit Sub
'Validate there is a sheet border
If Not osheet.Border Is Nothing Then
    Set oBorder = osheet.Border
Else
    MsgBox "Le dessin doit contenir une bordure", vbMsgBoxSetForeground, "AddDecoupeLine"
    Exit Sub
'Set start and end points of lines
Set LowPoint = invapp.TransientGeometry.CreatePoint2d(osheet.Width / 2, oBorder.RangeBox.MinPoint.Y)
Set HighPoint = invapp.TransientGeometry.CreatePoint2d(osheet.Width / 2, oBorder.RangeBox.MaxPoint.Y)
Set LeftPoint = invapp.TransientGeometry.CreatePoint2d(oBorder.RangeBox.MinPoint.x, osheet.Height / 2)
Set RightPoint = invapp.TransientGeometry.CreatePoint2d(oBorder.RangeBox.MaxPoint.x, osheet.Height / 2)
'Create Vertical line
Set oSketch = osheet.Sketches.add
oSketch.name = "Vertical"
oSketch.Edit
    oSketch.SketchLines.AddByTwoPoints LowPoint, HighPoint
oSketch.ExitEdit
'Create Horizontal line
oSketch.name = "Horizontal"
oSketch.Edit
    oSketch.SketchLines.AddByTwoPoints LeftPoint, RightPoint
oSketch.ExitEdit
AddPliageLineErr:
If Err Then
    MsgBox "Unexpected error during AddPliageLine routine: " & Err.Description, vbMsgBoxSetForeground + vbCritical, "AddPliageLine"
    Err.Clear
End Sub
Cheers,
Message 7 of 16
Tiffany_Hayden_
@yan.gauthier  Awesome sub! I'll try it out and see where I get. Thank you!
Tiffany Hayden
Message 8 of 16
Tiffany_Hayden_
@yan.gauthier
I tried to run your code but it didn't work.
I think the issue is my x and y coordinate is in model space. Do I need to add anything different to the code when referencing .X and .Y. I noticed that wasn't a choice in the intelisense.
                        Dim StartPoint As Point2d
                        Dim EndPoint As Point2d
                        Set StartPoint = ThisApplication.TransientGeometry.CreatePoint2d(GetDocWPt(oSubOcc.Definition.Document, "Center Point").X, GetDocWPt(oSubOcc.Definition.Document, "Center Point").Y)
                        Set EndPoint = ThisApplication.TransientGeometry.CreatePoint2d(GetDocWPt(oSubOcc.Definition.Document, "POINT FLOOR OUT").X, GetDocWPt(oSubOcc.Definition.Document, "POINT FLOOR OUT").Y)
                        Dim osketch As DrawingSketch
                        Set osketch = oSheet.Sketches.Add
                        osketch.Name = "Horizontal"
                        osketch.Edit
                            osketch.SketchLines.AddByTwoPoints StartPoint, EndPoint
                        osketch.ExitEdit
Tiffany Hayden
Message 9 of 16
Tiffany_Hayden_
Nevermind. missed adding .point! Thank you.
Tiffany Hayden
Message 10 of 16
Tiffany_Hayden_
@yan.gauthier  Well good news it's not erroring out but it's also not giving me what I'm wanting. Running this code It's creating two a line from 0,0 bottom left of sheet and making a vertical line. I'm not sure exactly why it's doing that but it might be because I'm referencing the points in model space. Is there a conversion that has to be made? Like scale or something?
                        Set StartPoint = ThisApplication.TransientGeometry.CreatePoint2d(GetDocWPt(oSubOcc.Definition.Document, "Center Point").Point.X, GetDocWPt(oSubOcc.Definition.Document, "Center Point").Point.Y)
                        Set EndPoint = ThisApplication.TransientGeometry.CreatePoint2d(GetDocWPt(oSubOcc.Definition.Document, "POINT FLOOR OUT").Point.X, GetDocWPt(oSubOcc.Definition.Document, "POINT FLOOR OUT").Point.Y)
'                        osketch.Name = "Horizontal"
                        osketch.Edit
                            osketch.SketchLines.Item(1).LineType = kDoubleDashedDottedLineType
                        osketch.ExitEdit
Tiffany Hayden
Message 11 of 16
yan.gauthier
I did some digging and apparently, you should create geometry proxies in your top assembly using the proxies you created in your sub occurrences.
Then, you can use the Sheet.Centermarks.AddByWorkFeature(GeometryProxy, View)
Solution was found here :
https://forums.autodesk.com/t5/inventor-customization/creating-a-centermark-from-a-workpoint-of-a-su...
Cheers,
Message 12 of 16
Tiffany_Hayden_
@yan.gauthierThanks! I'll try it out and let you know. Appreciate the digging. I dug all day yesterday! 🙂
Tiffany Hayden
Message 13 of 16
Tiffany_Hayden_
 @yan.gauthier Got the points coming in. But the line isn't working. When I add this it errors on this line.
'                        'Create a proxy for the two work points
                        Dim oWorkPointAssyProx1 As Inventor.WorkPointProxy
                        Call oCompOcc.CreateGeometryProxy(oWorkPointProx1, oWorkPointAssyProx1)
                        Dim oWorkPointAssyProx2 As Inventor.WorkPointProxy
                        Call oCompOcc.CreateGeometryProxy(oWorkPointProx2, oWorkPointAssyProx2)
                        Dim oCenterMarks1 As Centermarks
                        Dim oCenterMarks2 As Centermarks
                        Set oCenterMarks1 = oSheet.Centermarks
                        Set oCenterMarks2 = oSheet.Centermarks
                        Dim oCenterMark1 As Centermark
                        Dim oCenterMark2 As Centermark
                        Set oCenterMark1 = oCenterMarks1.AddByWorkFeature(oWorkPointAssyProx1, oView)
                        Set oCenterMark2 = oCenterMarks2.AddByWorkFeature(oWorkPointAssyProx2, oView)
                        Dim oSketch As DrawingSketch
                        Set oSketch = oSheet.Sketches.Add
                        oSketch.Edit
                            oSketch.SketchLines.AddByTwoPoints oCenterMark1, oCenterMark2
                            oSketch.SketchLines.Item(1).LineType = kDoubleDashedDottedLineType
                        oSketch.ExitEdit
Tiffany Hayden
Message 14 of 16
yan.gauthier
Use the centermarks to create your two point2d 😉
Message 15 of 16
Tiffany_Hayden_
OOHHH!!! Okay. Thank you!
Tiffany Hayden
Message 16 of 16
Tiffany_Hayden_
It works now!! Yay!!
What I had wrong for some time was using CenterMark.Position.X and Y. It was stuck there. 🙂 Thanks for all your help!!
For reference this is the code that worked. This is for oOcc and oSubOcc. For loop.
Yay! I'm so pumped. 🙂 Thanks again.
                        Dim oWorkPoint2 As Inventor.WorkPoint
                        Set oWorkPoint2 = GetDocWPt(oSubOcc.Definition.Document, "POINT FLOOR OUT")
                        Call oSubOcc.CreateGeometryProxy(oWorkPoint2, oWorkPointProx2)
                        Set oPointOne = oTG.CreatePoint2d(oCenterMark1.Position.X, oCenterMark1.Position.Y)
                        Set oPointTwo = oTG.CreatePoint2d(oCenterMark2.Position.X, oCenterMark2.Position.Y)
                        oSketch.Edit
                        Set oLine = oSketch.SketchLines.AddByTwoPoints(oPointOne, oPointTwo)
                        oSketch.ExitEdit
Tiffany Hayden
