Why EventAddIn sample does not work?
Hi,All,
I compile the VC++ AddIns sample "EventAddIn", and run it under
Inventor11,but I found that the select event does not work.
Whether I select a sketch line,the OK button in "Sketch Pattern" dialog is
alwayse gray.
I add a messagebox in selectEvent , try again, the messagebox does not show.
STDMETHODIMP CSelectEventHandler::onEvent_OnSelect(ObjectsEnumerator *
JustSelectedEntities,
SelectionDeviceEnum SelectionDevice, Point * ModelPosition,
Point2d * ViewPosition, View * View )
AFX_MANAGE_STATE(AfxGetStaticModuleState());
AfxMessageBox("Have Select!");
return m_pParent->OnSelect (JustSelectedEntities, SelectionDevice,
ModelPosition, ViewPosition, View );
Who can help me?
Thanks.
I couldn't reproduce the problem. Did you modify the code? I'd suggest you
step through the command code and check if the code in the
PatternSketchCmd::BeginCommand method is working correctly, especially the
calls to subscribe to the select events. Check if any Result values are not
returning S_OK. I couldn't think of anything obvious that might be wrong.
-Venkatesh Thiyagarajan.
"sdh" wrote in message
news:5205436@discussion.autodesk.com...
Hi,All,
alwayse gray.
Who can help me?
Thanks.
Thank you for your advice,.
I found that the PatternSketchCmd::BeginCommand method is OK,
CSelectEventHandler::onEvent_OnPreSelectMouseMove() and
CSelectEventHandler::onEvent_OnStopPreSelect() can work, but
CSelectEventHandler::onEvent_OnPreSelect() and
CSelectEventHandler::onEvent_OnSelect() does not work.
I didn't modify the sample code, only add a messagebox in event for test,
and every time add only in one event.
By the way, my compiler is vc++6.0.
sdh
"Venkatesh Thiyagarajan (Autodesk)" д
ÈëÓʼþ news:5206761@discussion.autodesk.com...
Hi,All,
alwayse gray.
Who can help me?
Thanks.
yosef
Community Visitor
Community Visitor
I have the same problem.
The event OnSelect isn't working in sample "EventAddIn" and in sample "CostomCommand" and in my own project.
But OnPreSelectMouseMove and OnStopPreSelect are working.
I'm using VC++6 and in my computer installed Visual Studio 2005.
I'm working in Inventor 11 and 10.
can someone help me?
