Where is this event?
Cris-Ideas
Advisor Advisor
Cris-Ideas
I am looking for event that should be there but it is not.
Does anyone know how to find it?
link to download video (better resolution): https://autode.sk/2MSyOAA
Cris.
Cris,
https://simply.engineering
AlexFielder
In the video you're changing the view-rep you want to make the occurrence associative to, I assume that since your current view rep is probably master, that may be why the check you are running always returns false?
Cris-Ideas
I do not think so.
Please look at 01:17.
this moment I am just unchecking associativity for YZ DVR.
Event that is triggeres indicates IsAssociativeToDesignViewRepresentation for this occurence as false for both before and after events.
I would rather expect that it should indicate true before and false after (opposite to what happened when I changed DVR to YZ associative previously). Surly before I uncheck associative occurrence is set to be associative.
than in 02:04 I set associativity again and event triggered indicates false before and true after.
and than directly after until 02:40
around 03:50 I have my occurrence set to be associative and last event that occurred also indicates this.
I than select to switch visibility to off and I am getting dialogue window informing me I need to remove associativity (so occurrence is associative in this moment) But after there is no event that would indicate IsAssociative state as true before and false after.
Cris.
Cris,
