When external VB program is run, open Inventor file and change Model States of Sub Assemblies.
C_Haines_ENG
Message 1 of 1
C_Haines_ENG
Very complicated issue, but I need to create a printing application that starts from an external application -> Opens a document and then changes all model states for all sub assemblies that contains "DOOR", based on values in a .txt document. I really just need help with changing models states of sub assemblies and printing.
If I could get even a basic script to change all models states of sub assemblies named "DOOR", that would be very helpful. This program will run in a .dwg file if that helps.
Replies (0)
