Cycle thru Occurrences with Model State Fails
SteveK88
SteveK88
This code runs fine in Inventor 2021 & Inventor 2023 if no part model state is used.
Fails in Inventor 2023 on any part that has a Model State.
Looking for a fix.
'Run in any assembly (iam) with a part (ipt) that has an active Model State
'Fails in Inventor 2023 if a part (ipt) has an active Model State
'Fails on line "Dim refDoc As PartDocument = occ.Definition.Document"
'Error code: Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
'Runs fine in Inventor 2021, Runs fine in Inventor 2023 if all parts (ipt) do NOT have an active Model State
'Code is meant to cycle thru all parts and turn On/Off visibility based on File Name. Runs fine in Inventor 2021 and earlier.
Dim assemblyDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim occ As Inventor.ComponentOccurrence
For Each occ In assemblyDef.Occurrences.AllLeafOccurrences
'MessageBox.Show("Full FileName " & refDoc.FullFileName, "TEST")
Next
dalton98
maybe try this?
If refDoc.ComponentDefinition.IsModelStateMember
	refDoc = occ.Definition.FactoryDocument
Next
SteveK88
Thanks for the reply,
Code Fails on,
So, changing Model State to Factory after this line will not work.
Manually changing all Model States to factory then running the code still fails on this same line.
dalton98
Try these
Dim refDoc As Document = occ.Definition.Document
Dim refDoc As PartDocument = occ.ReferencedDocumentDescriptor.ReferencedDocument
Try
Catch
Dim refDoc As PartDocument = occ.Definition.FactoryDocument
End Try
SteveK88
Still  not working with the Try statements.
I think there is an issue with occurrences and model states.
I am trying AllReferencedDocuments instead of occurrences.
SteveK88
Tried using AllReferencedDocuments but I need the occurrence to change visibility.
SteveK88
This will work for what I want.
	Dim oDoc As AssemblyDocument = ThisDoc.Document
	Dim oOccs As ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
    Dim oOcc As ComponentOccurrence
	i = 0
	v = 0
    For Each oOcc In oOccs
		SearchName1 = oOcc.Name.Contains("Bolt")
		If SearchName1 Then
			v=v+1
			'code for something
			Else
			i=i+1
			'Code for something
    Next
	MessageBox.Show("Counter " & i & ", " & v, "TEST")
