what is the correct way to write this iLogic?
chris
Advisor Advisor
Message 1 of 13
chris
I'm trying to write an iLogic rule for an angle constraint that has a slider in the Form, that says if "X" option is chosen then the angle  can only be between 20º and 179º, but if the option is "Y", then the angle can be any number between 181º and 340º (below is what I tried)
If Handrail_Style = "Straight" Then
Parameter("L2A") = 180
Parameter("L3A") = 180
Else If Handrail_Style = "L Shape" Then
Parameter("L2A") = <=20  And  >=179
Else If Handrail_Style = "C Shape" Then
Parameter("L3A") = <= 20 And >= 179
Else If Handrail_Style = "S Shape" Then
Parameter("L3A") = <=181 And >=340
End If
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
Replies (12)
Message 2 of 13
WCrihfield
Maybe like this?
ElseIf Handrail_Style = "L Shape" Then
	If Parameter("L2A") < 20 Then
		Parameter("L2A") = 20
	ElseIf Parameter("L2A") > 179 Then
		Parameter("L2A") = 179
	End If
ElseIf Handrail_Style = "C Shape" Then
	End If
	If Parameter("L3A") < 20 Then
		Parameter("L3A") = 20
	ElseIf Parameter("L3A") > 179 Then
		Parameter("L3A") = 179
	End If
ElseIf Handrail_Style = "S Shape" Then
	End If
	If Parameter("L3A") < 181 Then
		Parameter("L3A") = 181
	ElseIf Parameter("L3A") > 340 Then
		Parameter("L3A") = 340
	End If
End If
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 13
chris
@WCrihfield This sort of worked... let me simplify it, Osha says the maximum distance between vertical rails in a handrail is 72". I'm trying to write a rul that says something like this:
If the total handrail Length is less than or equal to the Osha Max imum vertical distance, then suppress the vertical rails, (as they are not needed), but if the handrail length is "greater than" the Osha maximum distance, then show the vertical rails.
Handrail Length = SL
Osha Max Vertical Distance = Osha_V_Off
Vertical Rail = SV
Vertical Rail Pattern = SV_Pat
below is what I tried... it suppresses the rails, but doesn't all ow them to show, even if the "SL" is a larger number than the "Osha_V_Off"
If SL = Osha_V_Off Then
	Feature.IsActive("SV") = False
	Feature.IsActive("Rectangular Pattern14") = False
	Else If SL > Osha_V_Off Then
Else If SL < Osha_V_Off Then
	Feature.IsActive("SV") = True
	Feature.IsActive("Rectangular Pattern14") = True
	End If
btw, I'm having the hardest time understanding how the equal to / greater than/less than operators should be listed or written... I'm writing them the way i would say them, but nothing seems to work?
Message 4 of 13
A.Acheson
The Else If vs ElseIf could be at play here. See stackoverflow description of Else If vs ElseIf
It should be written ElseIf. Also check if your parameters are what they should be with a message box. Updating of parameters during processing can be troublesome.
ElseIf SL > Osha_V_Off Then Feature.IsActive("SV") = False Feature.IsActive("Rectangular Pattern14") = False ElseIf SL < Osha_V_Off Then Feature.IsActive("SV") = True Feature.IsActive("Rectangular Pattern14") = True End If iLogicVb.UpdateWhenDone = True InventorVb.DocumentUpdate()
Regards
Alan
Message 5 of 13
chris
@A.Acheson thanks for the try, it suppresses the feature and pattern, but it doesn't do anything on the "greater than" portion, so it's still not working. All the tutorials I've watched on this only show people making a=B and then having a message pop up that says Yes or no... but what I haven't seen is any tutorial where they use it to drive another dimension or as I'm trying to do, suppress a feature(s)
Message 6 of 13
A.Acheson
Hi @chris
Does the logic itself work with a message box to say your in the elseif? If you are then it could be an issue with the feature control themselves.
Regards
Alan
Message 7 of 13
WCrihfield
Hi @chris.  They can be a little confusing at first if you have not yet used them that much in that many scenarios.  You can see the available options in the iLogic Rule editor dialog, under the 'Operators' drop-down.  When combining a single < or > with a =, the equal sign is always the second symbol (<= or >=).  When using the <= symbols together between two values, the statement will evaluate to True if the value on the left side of those 2 operators is less than or equal to the value on the right of those operators.  And when using the >= operators between two values, the statement will evaluate to True if the value to the left of those operators is greater than or equal to the value to the right of those operators.
Also keep in mind that when controlling suppression by code, they need to be done in propper order, or they may throw errors, or cause other problems.  For instance, you should suppress the component pattern before suppressing the component that the pattern is based uppon.  And you should unsuppress the component that the pattern us based upon, before unsuppressing the component pattern that is based on that component.  And just in general suppress the later created features that are dependant on earlier created features before suppressing the earlier created features that have other features dependant on them.  Then unsuppress the earlier features first, before unsuppressing the features that are depentant on the earlier features.  That means not simply using the same ordered list of stuff on both sides of an argument that is controlling suppression.
Wesley Crihfield
Message 8 of 13
Curtis_Waguespack
Hi @chris
I think you can reduce this all to two lines.
Feature.IsActive("SV") = (SL >= Osha_V_Off)
Feature.IsActive("Rectangular Pattern14") = (SL >= Osha_V_Off)
the Feature.IsActive function returns either true or false
the equation ( SL >= Osha_V_Off) also returns either true or false
so you can set these to together with an equal sign such as this:
so that the feature's active status is always whatever (SL >= Osha_V_Off) evaluates as.
so when Osha_V_Off is a constant of 72
if SL = 50, then (SL >= Osha_V_Off)  returns FALSE because 50 is not greater or equal to 72
if SL = 72, then (SL >= Osha_V_Off)  returns TRUE because 72 is equal to 72
if SL = 80, then (SL >= Osha_V_Off)  returns TRUE because 80 is greater than 72
I hope this helps.
Curtis
Message 9 of 13
chris
@Curtis_Waguespack That worked perfectly! Thank you, after seeing what you wrote, I have to say it differently in my head and consider writing things differently!
Message 10 of 13
chris
@Curtis_Waguespack On a side note, I have another part of this handrail design that I can control with the "limits" within the form setting a min and max angle, but is there a way to set the limits of a dimension within a range but also leaving a specific number out?
Example: I have a dimension "L2A" which controls the handrail angle, I have the limits set to be between 20º and 340º, but I want to "exclude" 180º. It would be nice if the limits wizard in iLogic would allow for "exclusions", but it only offers min/max
Message 11 of 13
Curtis_Waguespack
Hi @chris,
I can't think of better way than this, but I think this should work.
If L2A < 20 Then
	L2A = 20
ElseIf L2A > 340 Then
	L2A = 340
ElseIf L2A = 180 Then
	L2A = 179
End If
I hope this helps.
Curtis
Message 12 of 13
WCrihfield
That's a tough one.  I'm thinking another rule a bit similar to the first one may be needed to help control something like that.  Below is a simple example that could likely be used if you want it to work silently in the background.
oVal = Parameter("L2A")
If oVal < 20 Then
	oVal = 20
ElseIf oVal > 340 Then
	oVal = 340
ElseIf oVal = 180 Then
	oVal = 179 'or 181
End If
If Parameter("L2A") <> oVal Then Parameter("L2A") = oVal
or you could just use something like a warning message, that doesn't actually try to control its value, like this.
If oVal < 20 Or oVal = 180 Or oVal > 340 Then
	MessageBox.Show("The Value of 'L2A' must be between 20 & 340, but not 180", "Parameter Out Of Limits", _
	MessageBoxButtons.OK, MessageBoxIcon.Warning)
End If
Wesley Crihfield
Message 13 of 13
chris
@WCrihfield @Curtis_Waguespack Okay, I will try each of these... believe it or not, it would appear that a simple (well not so simple), handrail design has broken Inventor, lol 😞
