What is the correct way to write this iLogic code / Parameter equation?
chris
Advisor Advisor
chris
I want to round up a dimension, based on another dimension to the nearest 1/8".
Examples:
if d17 0.735, then I want d18 to = 0.75
if d21 = 0.317 then I want d22 to = 0.375
can you show this for both iLogic and for Parameters?
Andrii_Humeniuk
Hi @chris . I recommend trying the mathematical iLogic snippet "Round Closest to Increment".
inc = .125 ' rounding increment ( .125, .25, .5, etc)
roundedClosest = Round(Round(d0,4) / inc) * inc
Example formula for parameters:
round(d0 / 0,125 mm) * 0,125 mm
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
chris
@Andrii_Humeniuk  I think your example shows how to round a single dimension, but I am looking for one dimension to be rounded "up" based on a reference dimension... unless I'm missing something...?
Andrii_Humeniuk
You need to use the math function Ceil
For iLogic:
roundedClosest = Ceil(d0/inc) * inc
For Parameters:
Ceil(d0 / 0,125 mm) * 0,125 mm
marcin_otręba
There is no need to use ilogic , you can just use formula in parameters as @Andrii_Humeniuk wrote:
it will round it up as you wanted.
but f you want to use formula in ilogic then it would look like:
Parameter("d18") = (Ceil(d17 / 0.125) * 0.125)
Parameter("d22") = (Ceil(d21 / 0.125) * 0.125)
iLogicVb.UpdateWhenDone = True
here is help reference:
Inventor 2025 Help | Math Functions Reference (iLogic) | Autodesk
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
