What is iLogic code for "re-run all rules?'
acadadmin3KNUF
acadadmin3KNUF
Hello to all:
What is the iLogic command to re-run every rule in a single part document, if there is one?
Michael.Navara
You can use this code as first approach. This rule MUST BE external rule.
For Each rule In iLogicVb.Automation.Rules(ThisDoc.Document)
	iLogicVb.Automation.RunRuleDirect(rule)
Next
WCrihfield
Hi @acadadmin3KNUF.  Here is another one that should work for you.  There is a button for this command on the Manage tab > iLogic panel, called Regenerate All Rules.  When you click it, it will run all of the local/internal rules in that document, as part of what it does.  You can read more about it by hovering your mouse over it.
ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.RegenAllRules").Execute
Warning:  Make sure the document you want to work on is currently, visibly open on your screen, not just a referenced document of an assembly that you may have open, because there is no way to tell it which document you want it to work on.
Wesley Crihfield
(Not an Autodesk Employee)
