Welding Symbol
Welding Symbol
JMGunnar
Welding Symbol
JMGunnar
I know about that weldsymbol not have Api
but is thera any options too collect weldsymbol too reattacment again
Best Regards Johan
like
Sub Main()
    ' Set a reference to the active drawing document
    Dim oDoc As DrawingDocument
    oDoc = ThisDoc.Document 'ThisServer.ActiveDocument
    ' Set a reference to the active sheet
	Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    ' Iterate over all Weldingsymbol in the drawing
    ' and delete unattached (sick) dimensions.
   Dim oSelectset As SelectSet
	   oSelectset = oDoc.SelectSet
       oSelectset.Clear
	Dim oTG As TransientObjects
	    oTG = ThisApplication.TransientObjects
	 Dim oLeaderCollection As ObjectCollection
	    oLeaderCollection = oTG.CreateObjectCollection
	Dim oLeaderNote As LeaderNote
	For Each oLeaderNote In oSheet.DrawingNotes.LeaderNotes
		 	 oLeaderCollection.Add(oLeaderNote)
	Next
   	oSelectset.SelectMultiple(oLeaderCollection)
	'ThisApplication.CommandManager.ControlDefinitions.Item("DLxAnnoReconnectCmd").Execute
	ThisApplication.CommandManager.ControlDefinitions.Item("DLxAutoReattachSickAnnotationsCmd").Execute
    oSelectset.Clear
	End Sub
JMGunnar
Have any do some SelectSet code that use
custom filter
is any options i find too get only Weldsymbol..
Johan
            oSelectset.Clear
