Weird results with transient BREP graphics
basautomationservices
Message 1 of 9
Hi all,
I'm trying to draw a plane using the interactiongraphics and a transientsurfacebody. But I'm getting very strange results. There is a VBA sample of the code I'm using below.
I'm creating a list of points. These points are shown as point graphics, and are in the correct position.
Then I'm creating edges to form a face and creating a transient surfacebody.
Weirdly, the surface is a quarter of the area it should be. I'm printing the start and end points of the edges and they are correct. The surface is simply not correctly created from the inputs. What could be happening here?
Option Explicit
Private Const WIDTH As Double = 20
Private Const HEIGHT As Double = WIDTH
Private app As Application
Private doc As Document
Private compDef As PartComponentDefinition
Private graphicsData As GraphicsDataSets
Private clientGraphics As clientGraphics
Private Nodes As Collection
Private tempNodes As Collection
Sub test()
    Dim part As PartDocument
    Set part = ThisApplication.ActiveDocument
    Dim interactionEvents As interactionEvents
    Set interactionEvents = ThisApplication.CommandManager.CreateInteractionEvents()
    Dim interactionGraphics As interactionGraphics
    Set interactionGraphics = interactionEvents.interactionGraphics
    Call Initialize(interactionGraphics, part)
    Call AddPlane(part.ComponentDefinition.WorkPlanes.Item(2))
End Sub
Public Sub Initialize(interactionGraphics As interactionGraphics, partDoc As PartDocument)
    Set app = ThisApplication
    Set doc = partDoc
    Set compDef = partDoc.ComponentDefinition
    Set graphicsData = interactionGraphics.GraphicsDataSets
    Set clientGraphics = interactionGraphics.PreviewClientGraphics
    Set Nodes = New Collection
    Set tempNodes = New Collection
End Sub
Private Function CreateNewGraphicsNode() As GraphicsNode
    Dim ids As Collection
    Dim node As GraphicsNode
    Dim nodeId As Integer
    Dim n As GraphicsNode
    Set ids = New Collection
    For Each n In clientGraphics
        ids.Add n.Id
    Next n
    nodeId = 1
    If ids.count > 0 Then
        nodeId = ids.Item(ids.count) + 1
    On Error GoTo ErrorHandler
    Set node = clientGraphics.AddNode(nodeId)
    tempNodes.Add node
    Nodes.Add node
    Set CreateNewGraphicsNode = node
    Exit Function
ErrorHandler:
    Err.Raise vbObjectError, , "Failed to add a GraphicsNode. ClientGraphics object might be broken, or node ID is invalid."
End Function
Private Sub AddPointGraphics(node As GraphicsNode, points As Collection)
    Dim pointGraphic As PointGraphics
    Dim cset As GraphicsCoordinateSet
    Dim i As Integer
    Dim point As point
    Set pointGraphic = node.AddPointGraphics
    Set cset = graphicsData.CreateCoordinateSet(1)
    pointGraphic.coordinateSet = cset
    i = 1
    For Each point In points
        cset.Add i, point
        i = i + 1
    Next point
    pointGraphic.PointRenderStyle = kCirclePointStyle
End Sub
Private Function GetPoints() As Collection
    Dim points As Collection
    Dim tg As TransientGeometry
    Set points = New Collection
    Set tg = app.TransientGeometry
    points.Add tg.CreatePoint(-WIDTH / 2, -HEIGHT / 2)
    points.Add tg.CreatePoint(-WIDTH / 2, HEIGHT / 2)
    points.Add tg.CreatePoint(WIDTH / 2, HEIGHT / 2)
    points.Add tg.CreatePoint(WIDTH / 2, -HEIGHT / 2)
    Set GetPoints = points
End Function
Private Sub AddSurfaceGraphics(node As GraphicsNode, points As Collection, plane As plane)
    Dim bodyDef As SurfaceBodyDefinition
    Dim lumpDef As LumpDefinition
    Dim faceDef As FaceShellDefinition
    Dim face As FaceDefinition
    Dim loopDef As EdgeLoopDefinition
    Dim i As Integer
    Dim j As Integer
    Dim p1 As point, p2 As point
    Dim lineSegment As lineSegment
    Dim v1 As VertexDefinition, v2 As VertexDefinition
    Dim edgeDef As EdgeDefinition
    Dim body As SurfaceBody
    Dim errors As Object
    Set bodyDef = app.TransientBRep.CreateSurfaceBodyDefinition
    Set lumpDef = bodyDef.LumpDefinitions.Add
    Set faceDef = lumpDef.FaceShellDefinitions.Add
    Set face = faceDef.FaceDefinitions.Add(plane, True)
    Set loopDef = face.EdgeLoopDefinitions.Add
    For i = 1 To points.count
        j = GetNextIndex(i, points.count)
        Set p1 = points(i)
        Set p2 = points(j)
        Set lineSegment = app.TransientGeometry.CreateLineSegment(p1, p2)
        Set v1 = bodyDef.VertexDefinitions.Add(p1)
        Set v2 = bodyDef.VertexDefinitions.Add(p2)
        Set edgeDef = bodyDef.EdgeDefinitions.Add(v1, v2, lineSegment)
        loopDef.EdgeUseDefinitions.Add edgeDef, True
        Debug.Print ("Startpoint")
        Debug.Print ("X: " + CStr(edgeDef.StartVertex.Position.X))
        Debug.Print ("Y: " + CStr(edgeDef.StartVertex.Position.Y))
        Debug.Print ("Z: " + CStr(edgeDef.StartVertex.Position.Z))
        Debug.Print ("Endpoint")
        Debug.Print ("X: " + CStr(edgeDef.EndVertex.Position.X))
        Debug.Print ("Y: " + CStr(edgeDef.EndVertex.Position.Y))
        Debug.Print ("Z: " + CStr(edgeDef.EndVertex.Position.Z))
    Next i
    Set body = bodyDef.CreateTransientSurfaceBody(errors)
    If Not errors Is Nothing Then
        Err.Raise vbObjectError, , "Failed to create the transient face"
    Dim surfaceGraphics As surfaceGraphics
    Set surfaceGraphics = node.AddSurfaceGraphics(body)
    surfaceGraphics.Color = app.TransientObjects.CreateColor(0, 135, 0, 0.2)
End Sub
Private Function GetNextIndex(i As Integer, count As Integer) As Integer
    If i = count Then
        GetNextIndex = 1
    Else
        GetNextIndex = i + 1
End Function
Public Function AddPlane(wp As WorkPlane) As GraphicsNode
    Dim plane As plane
    Set plane = wp.plane
    Set node = CreateNewGraphicsNode()
    node.Selectable = True
    Set points = GetPoints()
    AddPointGraphics node, points
    AddSurfaceGraphics node, points, plane
    Set AddPlane = node
End Function
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Replies (8)
Message 2 of 9
anyone?
Message 3 of 9
Still have this problem. Anyone?
Message 4 of 9
I have edited the original post and provided VBA sample code!
Message 5 of 9
b_nederveenHJY8C
Anyone? I really don't see if I'm making a mistake or if this is a bug..
(posted with wrong account by accident...)
@MjDeck
Message 6 of 9
MjDeck
Hi @b_nederveenHJY8C , sorry we didn't reply sooner.
The problem is that you're specifying the wrong plane for the points. The system creates something. Maybe it should throw an error instead.
Based on the points, you want the XY plane. To get it, change this line:
to this:
    Call AddPlane(part.ComponentDefinition.WorkPlanes.Item(3))
Mike Deck
Software Developer
Autodesk, Inc.
Message 7 of 9
No problem, thanks for the reply anyhow!!
Haha okay. I feel so dumb now. The index is 1 based ofcourse..
Message 8 of 9
_dscholtes_
Hello @basautomationservices
First, I'm curious to know why you took this elaborate route to create a new graphics node. Wouldn't the following suffice?
Set node = clientGraphics.AddNode(clientGraphics.Count + 1)
Second, I'm wondering why you took the TransientBRep route and didn't use TriangleStripGraphics to display a plane?
These provide a connected set of triangles. The first three coordinates define a triangle and the next coordinate defines another triangle using the previous two coordinates. This is provided for performance reasons.
Message 9 of 9
Hi @_dscholtes_
I used this route because the code is from an addin where I need to manage multiple graphic nodes throughout a session. I want to show/delete nodes. It's been a while, and am on holiday at the moment so am not exactly sure anymore what was the reason but I believe I was getting some errors after removing nodes.
Easiest way to create some sample vba code was to remove (some) unused code, throw everything in chatGPT, convert to vba and then make the code work. So it's just some sample code to illustrate the problem basically.
Second; I found some example somewhere, had no clue trianglestripgraphics existed 😳 will try it out when back at home!
