Issue with Drawing Weld Symbol Creation in Inventor 2024
gopinadh7XTGG
Message 1 of 1
gopinadh7XTGG
Hello All,
I was trying to create a Drawing weld symbol of Surfacing weld symbol type in Inventor 2024. I was getting this error (The remote procedure call failed. (Exception from HRESULT: 0x800706BE)) and Inventor is terminated only for the Surfacing weld symbol type Enum (WeldSymbolTypeEnum.kSurfacingOrCladdingWeldSymbolType). All other types are working fine. Below is the code I am using and attached are the cad files I am using for testing purpose.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=WeldSymbolTypeEnum
Any help is appreciated.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Threading.Tasks;
using System.Windows.Forms;
using Inventor;
using System.Runtime.InteropServices;
namespace Testcase_Inv2024_WeldSymbol_Creation
static class Program
static void Main()
Inventor.Application oApp = Marshal.GetActiveObject("Inventor.Application") as Inventor.Application;
DrawingDocument drawingDocument = oApp.ActiveDocument as DrawingDocument;
Sheet oActiveSheet = drawingDocument.ActiveSheet;
// Set a reference to the drawing curve segment.
// Please select a linear drawing curve.
DrawingCurveSegment oDrawingCurveSegment =
oApp.CommandManager.Pick(
SelectionFilterEnum.kDrawingCurveSegmentFilter,
"Select a linear curve") as DrawingCurveSegment;
// Set a reference to the drawing curve.
DrawingCurve oDrawingCurve = oDrawingCurveSegment.Parent;
// Get the mid-point of the selected curve
// assuming that the selection curve is linear.
Point2d oMidPoint = oDrawingCurve.MidPoint;
// Set a reference to the TransientGeometry object.
TransientGeometry oTG = oApp.TransientGeometry;
// Create an ObjectCollection for leader points.
ObjectCollection oLeaderPoints = oApp.TransientObjects.CreateObjectCollection();
// Create a few leader points.
oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 1, oMidPoint.Y + 1));
// Create an intent and add it to the leader points collection.
// This is the geometry that the symbol will attach to.
GeometryIntent oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, oMidPoint);
//oLeaderPoints.Add(oMidPoint);
oLeaderPoints.Add(oGeometryIntent);
// Set a reference to the DrawingWeldingSymbolDefinitions.
DrawingWeldingSymbolDefinitions oWeldingSymDefs = oActiveSheet.WeldingSymbols.CreateDefinitions();
// Add a welding symbol definition.
DrawingWeldingSymbolDefinition oWeldingSymDef = oWeldingSymDefs.Add(1);
// Specify the weld symbol type (WeldSymbolTypeEnum/BackingSymbolTypeEnum).
//oWeldingSymDef.WeldSymbolOne.WeldSymbolType = (int)WeldSymbolTypeEnum.kFilletWeldSymbolType;
oWeldingSymDef.WeldSymbolOne.WeldSymbolType = (int)WeldSymbolTypeEnum.kSurfacingOrCladdingWeldSymbolType;
oWeldingSymDef.WeldSymbolTwo.WeldSymbolType = (int)WeldSymbolTypeEnum.kNoneWeldSymbolType;
oWeldingSymDef.ClosedNoteTail = true;
oWeldingSymDef.TailNote = "2X";
oWeldingSymDef.AllAroundSymbol = true;
oWeldingSymDef.FieldWeldingSymbol = true;
// Create the symbol with a leader.
DrawingWeldingSymbol oSymbol = oActiveSheet.WeldingSymbols.Add(oLeaderPoints, oWeldingSymDefs);
Replies (0)
