weird AllReferencedDocuments results
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey
Im getting wierd results with using AllreferencedDocuments. When done in VB.Net using Apprentice, the exact same file from the same folder location can have mixed results. Mainly, any iPart used sometimes references the factory part and sometimes doesnt. The same code in VBA does but takes longer...
The only different in the code are the following lines:
VB.Net (Apprentice)
Dim drawingDoc As Inventor.ApprenticeServerDocument = apprenticeServer.Open(CDFilename)
Dim allReferencedDocs As Inventor.ApprenticeServerDocuments = drawingDoc.AllReferencedDocuments
Dim referencedDoc As Inventor.ApprenticeServerDocument
For Each referencedDoc In allReferencedDocs
Debug.Print(referencedDoc.DisplayName)
Next
VBA
Dim DrawingDoc As String
DrawingDoc = "K:\Inventor\Templates\REF FILES\MASTERDOC.idw"
Dim oDoc As Document
Set oDoc = ThisApplication.Documents.Open(Path, False)
Dim oRefDocs As DocumentsEnumerator
Set oRefDocs = oDoc.AllReferencedDocuments
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
Debug.Print oRefDoc.DisplayName
Next
oDoc.Close (True)
VBA uses DocumentEnumerator whereas Apprentice uses ApprenticeServerDocuments
Why would apprentice return different results using the exact same code on the exact same file?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
