Was the ability to set Event Triggers through iLogic removed in 2025.3?
Zackery.Breeland
Zackery.Breeland
I had a custom program developed to assign event triggers using external rules directories that used to work.  Did the update to Inventor 2025.3 break and/or remove the code that made this possible?
mfoster9TD82
This is an old post but it might still work. I believe I've done this before, but I couldn't find a sample
https://forums.autodesk.com/t5/inventor-programming-forum/is-it-possible-to-add-an-event-trigger-usi...
