Autodesk Inventor AddIn Template - Download
Crstiano
Message 1 of 8
Crstiano
Can someone share the VBInventorAddinTemplate202x.zip file (2021-2023)?
developertools.msi doesn't recognize VS2022, so if someone posts the link to download the template I can use it.
Thanks a lot.
Cristiano Oliveira
ConsultCAD.com
Accepted solutions (3)
Replies (7)
Message 2 of 8
Frederick_Law
You can "unpack" the msi file.
Message 3 of 8
Crstiano
Cristiano Oliveira
ConsultCAD.com
Message 4 of 8
Crstiano
Can someone share the VBInventorAddinTemplate2025.zip file ?
The same happens again.. installed the SDK and not regnonize the templates... 😕
Cristiano Oliveira
ConsultCAD.com
Message 5 of 8
Curtis_Waguespack
see attached
Message 6 of 8
Curtis_Waguespack
C# addin templates in case it helps someone else
VCSInventorAddInTemplate2022.zip
Message 7 of 8
jaquinYX4QT
I've encountered the same problem. Just to let you know, the DeveloperTool.MSI did copy the files in my user VS Studio template locations in "My Documents\VS..." folder on the computer, but still I was not able search the template in VS New Project page. However, in VS options for template location, I noticed that instead of "My Documents\...", it refers to my organization's "OneDrive\My Document\..." Before using OneDrive service, I was not encountering those type of path issues. Copying the tamplate in the OneDrive's Doc location fixed the issue for me. Thank you for the files BTW.
Message 8 of 8
j.romoYDW7Q
I have been using for my addins the  @JelteDeJong tutorial to set up your own project manually http://www.hjalte.nl/tutorials, and works like a charm.
