Waiting until part of rule is complete to finish rule
KWarrenCA
KWarrenCA
I've got a rule that creates a view, hides certain parts, creates simplified part, and match iProperties of the assembly. It works well with smaller assemblies but when it runs on larger assemblies the simplified part creation takes a while and then it doesn't save the file and copy the iProperties over. Is there any way to keep it from moving forward at line 114 until the earlier part of the rule is completed?
Class iRule
	Public oView As DrawingView
	Public oSheet As Sheet
	Public oPartslist As PartsList
	Public oCompDef As ComponentDefinition
	Public oNewFullName As String
	Sub Main()
		Q = MessageBox.Show("You are about to create an Asset View and Simplified Part this may take a few minutes to complete. Click Cancel to stop the rule from running.", "Simplified Part", MessageBoxButtons.OKCancel, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
		If Q = vbOK Then 'Action
		ElseIf Q = vbCancel Then
			Exit Sub
			oSrcDWG = ThisApplication.ActiveDocument
			oCompDef = oSrcDWG.ComponentDefinition
			Try
				oCompDef.RepresentationsManager.DesignViewRepresentations.Item("ASSET VIEW").Activate
				SimplifiedPartCreation(oSrcDWG)
				CopyIproperties(oSrcDWG)
			Catch
				ViewCreation(oSrcDWG)
				PartTurnOFF(oSrcDWG)
			End Try
		'CopyIproperties(oSrcDWG)
	End Sub
	Sub ViewCreation(oSrcDWG)
		'Creates Representation
		Dim oviewrep As DesignViewRepresentation
		Try
		Catch
			oviewrep = oCompDef.RepresentationsManager.DesignViewRepresentations.Add("ASSET VIEW")
			'Activate new View Rep
			oviewrep.activate
		End Try
		'Turn off ALL object visibility
		ThisApplication.ActiveDocument.ObjectVisibility.AllWorkfeatures = False
		ThisApplication.ActiveDocument.ObjectVisibility.ConstructionSurfaces = False
		ThisApplication.ActiveDocument.ObjectVisibility.Sketches = False
		ThisApplication.ActiveDocument.ObjectVisibility.Sketches3D = False
		ThisApplication.ActiveDocument.ObjectVisibility.SketchDimensions = False
		ThisApplication.ActiveDocument.ObjectVisibility.Annotations3D = False
		If oSrcDWG.DocumentType = kAssemblyDocumentObject Then
			ThisApplication.ActiveDocument.ObjectVisibility.WeldmentSymbols = False
			ThisApplication.ActiveDocument.ObjectVisibility.Welds = False
		iLogicVb.UpdateWhenDone = True
	End Sub
	Sub PartTurnOFF(oSrcDWG)
		'Hides Parts in assembly for view
		Dim assemblyDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
		Dim occ As Inventor.ComponentOccurrence
		For Each occ In assemblyDef.Occurrences.AllLeafOccurrences
			Dim refDoc As PartDocument = occ.Definition.Document
			'MessageBox.Show(occ.Name.ToString, "Title")
			'MessageBox.Show(iProperties.Value(occ.Name,"Project", "Part Number").ToString, "Title")
			''ADD MORE IF STATEMENTS ON OTHER PARTS TO REMOVE
			If iProperties.Value(occ.Name, "Project", "Vendor").Contains("HARDWARE") Then
				occ.Visible = False
			Else If iProperties.Value(occ.Name, "Project", "DESCRIPTION").Contains("CLAMP") Then
			occ.Visible = False
			Else If iProperties.Value(occ.Name, "Project", "DESCRIPTION").Contains("GASKET") Then
			occ.Visible = False
			'USE TO TURN PARTS ON
			'occ.Visible = True
			Else If iProperties.Value(occ.Name, "Project", "DESCRIPTION").Contains("PLUG") Then
			occ.Visible = False
		Next
	End Sub
	Sub SimplifiedPartCreation(oSrcDWG)
		'Creates Simplified part
		Try
			Dim oFileName As String = IO.Path.GetFileNameWithoutExtension(oSrcDWG.FullFileName)
			Dim oPartDoc As PartDocument
			Dim g_App As Inventor.InventorServer = ThisApplication
			Dim AssDoc As Inventor.AssemblyDocument = ThisDoc.Document
			'Create a new part document that will be the shrinkwrap substitute
			oPartDoc = g_App.Documents.Add(DocumentTypeEnum.kPartDocumentObject, , True)
			Dim oPartDef As PartComponentDefinition
			oPartDef = oPartDoc.ComponentDefinition
			Dim oDerivedAssemblyDef As DerivedAssemblyDefinition
			oDerivedAssemblyDef = oPartDef.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(AssDoc.FullDocumentName)
			' Set various shrinkwrap related options
			oDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsMultipleBodies
			oDerivedAssemblyDef.IncludeAllTopLevelWorkFeatures = DerivedComponentOptionEnum.kDerivedExcludeAll
			oDerivedAssemblyDef.IncludeAllTopLevelSketches = DerivedComponentOptionEnum.kDerivedExcludeAll
			oDerivedAssemblyDef.IncludeAllTopLeveliMateDefinitions = DerivedComponentOptionEnum.kDerivedExcludeAll
			oDerivedAssemblyDef.IncludeAllTopLevelParameters = DerivedComponentOptionEnum.kDerivedExcludeAll
			Call oDerivedAssemblyDef.SetHolePatchingOptions(DerivedHolePatchEnum.kDerivedPatchNone)
			Call oDerivedAssemblyDef.SetRemoveByVisibilityOptions(DerivedGeometryRemovalEnum.kDerivedRemoveNone)
			Dim oDerivedAss As DerivedAssemblyComponent
			oDerivedAss = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef)
			' Call oDerivedAss.SuppressLinkToFile(True)
			' Save the part
			Dim partname As String = ThisDoc.PathAndFileName(False) & " - SIMPLIFIED.ipt"
			ThisApplication.ActiveView.Fit
			ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
			Call oPartDoc.SaveAs(partname, False)
		Catch ex As Exception
			ErrorMessage = "Error creating ipt file."
		End Try
	End Sub
	Sub CopyIproperties(ByVal oSrcDWG As Document)
		'Used to Match iProperties to newly created part.
		toDoc = ThisApplication.ActiveDocument
		Dim fromPs As PropertySet
		For Each fromPs In oSrcDWG.PropertySets
			Dim toPs As PropertySet
			If Not toDoc.PropertySets.PropertySetExists(fromPs.InternalName) Then
				toPs = toDoc.PropertySets.Add(fromPs.Name, fromPs.InternalName)
			Else
				toPs = toDoc.PropertySets(fromPs.InternalName)
			Dim fromP
			For Each fromP In fromPs
				Dim toP
				On Error Resume Next
				toP = toPs.ItemByPropId(fromP.PropId)
				If Err.Number <> 0 Then
					toP = toPs.Add(fromP.Value, fromP.Name, fromP.PropId)
				Else
					toP = toPs(fromP.Name)
					If fromP.Value <> Nothing Then
						toP.Value = fromP.Value
				On Error GoTo 0
			Next
		Next
		i = MessageBox.Show("Your Simplified part has been completed."& vbCrLf &"Verify your model is correct and finish these steps"& vbCrLf &" - Suppress link with base component"& vbCrLf &" - Check simplified part into the Vault"& vbCrLf &" - Publish Asset", "Asset Creation", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	End Sub
End Class
A.Acheson
Hi @KWarrenCA
Not sure exactly what is causing the not waiting scenario. The setting of isometric view is driven by control definition so that usually doesn't wait before moving to next line of code.
You can use a loop like this if there is known updates happening but you will need to  heck if this would indeed be activated in the right location.
Do While Document.RequiresUpdate() = False
	Call  ThisApplication.UserInterfaceManager.DoEvents
Loop
The other thing I noticed is that your using different versions of the document object such as ThisApplication.ActiveDocument and ThisDoc.Document so it would be best to stick with one and or pass through the object to be used later. Maybe run a check also on the document fullfilename to ensure your getting the right document active when working through the sub routine. Even confirm this with Document.Activate.
Regards
Alan
KWarrenCA
Thanks @A.Acheson for the help I wasn't able to get the do loop to work correctly but I separated the save as its own sub which then help. Below is the fixed code that made it work.
Class iRule
	Sub Main()
			Exit Sub
		Try
			SaveFile(oSrcDWG)
		Catch
			SaveFile(oSrcDWG)
		End Try
	End Sub
		Try
		Catch
			oviewrep.activate
		End Try
	End Sub
			If iProperties.Value(occ.Name, "Project", "Vendor")="HARDWARE" Then
				occ.Visible = False
			occ.Visible = False
			occ.Visible = False
			'occ.Visible = True
			occ.Visible = False
		Next
	End Sub
		Try
			oDerivedAssemblyDef.IsAssociativeDesignView = True
			'oDerivedAssemblyDef.IncludeAllSketches
			'oDerivedAssemblyDef.IncludeAllParameters
'			'Call oDerivedAss.SuppressLinkToFile(True)
		End Try
	End Sub
	Sub SaveFile(oSrcDWG)
		Call toDoc.SaveAs(partname, False)
	End Sub
			Else
			Dim fromP
				Dim toP
				Else
				On Error GoTo 0
			Next
		Next
		'i = MessageBox.Show("All iProperties have been copied", "iProperties have been updated", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
ThisApplication.ActiveDocument.UnitsOfMeasure.lengthunits = UnitsTypeEnum.kInchLengthUnits
			ThisApplication.ActiveDocument.UnitsOfMeasure.Massunits = UnitsTypeEnum.kLbMassMassUnits
			ThisApplication.ActiveDocument.ComponentDefinition.Material.Name = "AS SUPPLIED"
		i = MessageBox.Show("Your Simplified part has been completed." & vbCrLf & "Verify your model is correct and finish these steps" & vbCrLf & " - Suppress link with base component" & vbCrLf & " - Check simplified part into the Vault" & vbCrLf & " - Publish Asset", "Asset Creation", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	End Sub
End Class
