Check for Disconnected Model in IDW
MarkyTomm
MarkyTomm
Hi All,
Quick question - is there a way to check for a disconnected model in an Inventor IDW
I want to scan through all sheets and if the model is disconnected (meaning that I have deleted it from the project) then delete that sheet.
Have my usual code snippet here - I may be using the wrong call by looking at the drawing view
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oView As DrawingView
On Error Resume Next
For Each oActiveSheet In oDoc.Sheets
oActiveSheet.Activate
Set oView = oDoc.ActiveSheet.DrawingViews(1)
*****Code here to check if the model is disconnected and delete the sheet if it is ********
Next
Any help, much appreciated
Regards
Mark
JelteDeJong
You can try something like this:
Dim doc As DrawingDocument = ThisDoc.Document
Dim disconectedSheets As New List(Of Sheet)
For Each sheet As Sheet In doc.Sheets
    For Each view As DrawingView In sheet.DrawingViews
        If (view.ReferencedDocumentDescriptor.ReferencedDocument Is Nothing) Then
            disconectedSheets.Add(sheet)
    Next
Next
For Each sheet As Sheet In disconectedSheets
    sheet.Delete()
Next
Jelte de Jong
Blog: hjalte.nl - github.com
WCrihfield
Hi @MarkyTomm.  Looks like my response is a little slower, but it is in VBA, since your initial code seemed to be in VBA, and I don't use that much anymore.  You can give this version a try though, just in case it may work any better for you.  In this code I am checking if the 'reference is missing', instead of Is Nothing, because draft views may also not have a referenced document, and I did not know if you had any of those.
Sub DeleteSheetsWithMissingModelLinks()
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
		Call MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oDDoc As DrawingDocument
	Set oDDoc = ThisApplication.ActiveDocument
	Dim oSheets As Inventor.Sheets
	Set oSheets = oDDoc.Sheets
	Dim oSheet As Inventor.Sheet
	For Each oSheet In oSheets
		Dim oViews As DrawingViews
		Set oViews = oSheet.DrawingViews
		If oViews.Count = 0 Then Continue For
		Set oView = oViews.Item(1)
		If oView.ReferencedDocumentDescriptor.ReferenceMissing Then
			oSheet.Delete
	Next
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
MarkyTomm
Many tanks guys - going to go with the reference missing version coupled with the add sheet references to an array and delete at the end which I think will excute quickest. Will throw in an active sheet and user confirm dialogue just for checking. Will post the code here when finished. Have a good one!
