Visual Studio question
PACDrafting
PACDrafting
In Visual Studio, how do I decipher through the API when debugging? (Similar to using the Locals Window in VBA).
philippe.leefsma
Hi PACDrafting,
Place a break point and use the watch window...
However the .Net debugger is less powerful than the VBA one, for example you wont be able to visualize the conte^nt of the collections, unless you write code to iterate through them.
This is a very general question, you may want to browse a bit the web in order to find tutorial on Visual Studio and debugging.
I hope it helps.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
Philippe Leefsma
Autodesk Developer Network
PACDrafting
Thanks very much.
